This post covers motherboard issues as well as other questions regarding a new system that I am to build. I appreciate any input regarding the ideas I have here. Thanks in advance!
** Goals **
A quiet rig for digital audio production, recording, MIDI etc.. but that can also be used
for gaming sometimes.
** What I have **
Thermalright SLK-900(A) Copper Heatsink for Socket A
Panaflo L1A 80mm Fans (3)
Zalman ZM80C-HP VGA Heatpipe Cooler
Zalman FanMate 1 Fan Speed Controllers (3)
Zalman ZM-NB32J Northbridge Heatsink
Arctic Silver 5 Thermal Paste
Silent Systems 3.5" HDD Cover
Echo Layla soundcard with 19" rack-mount break-out box
Plextor 48x24x48 CD-RW
Two LG Electronics 19" monitors
** What I plan to get **
Lian-Li PC-6070 Aluminum Case (has full door and acoustic foam lining) [$160]
PSU - 'silent' type, perhaps Seasonic Tornado, Nexus or Enermax (350-400 watts) [$90]
Abit AN7 Motherboard [$105]
AMD AthlonXP Mobile 2500+ CPU [$95]
Corsair XMS PC3200 TwinX 512mb or 1gb (2-3-2-6) [$150-$300]
Seagate 160mb SATA HDD [$120]
Radeon 9600 pro / 9800 pro [$110-$200]
** Ideas **
I have read that I can overclock the 2500+ mobile CPU to 2.2GHz with an increase in voltage
to only 1.525, I am hoping that the big heatsink and Panaflo L1A CPU fan (@7v) will keep temps under 60 C
I plan to have just one case fan, a Panaflo running at 7 volts on the back of the case
I plan on removing the northbridge fan and replacing with Zalman heatsink
I plan on removing VGA card fan and replacing with huge Zalman heatsink/heatpipe
I will be running both monitors from same AGP video card
Noise will only be generated by the two Panaflo L1A fans and the PSU fans.
** Questions **
Should I get PC3700 DDR rather than PC3200? Will I want to increase the FSB beyond
what the PC3200 DDR can handle?
How high a consistent CPU temp can I really be comfortable with?
The Abit AN7 will be a better choice than the NF7-S after a couple
BIOS revisions, right? I like the uGuru concept, with programmable overclocking presets
I could have a setting for gaming and a setting for music composition/recording. I know
that Nvidia makes a software app that has a similar function for the NF7-S but I have read
that it is not as good at the uGuru hardware chip.
Thanks to everyone for any ideas regarding my future rig, I am really excited about gettingit built and tweaking it to perfection.. I have found quite a bit of info regarding silent PC computing here:
http://www.silentpcreview.com/
http://home.swipnet.se/tr/silence.html
Thanks Again! -morc
** Goals **
** What I have **
** Ideas **
** Questions **
Thanks Again! -morc
