Any one heard anout DFI motherboard with Intel P4 2.8E, I just buy this motherboard and recommanded by the techinician. After I start to use this board I foundt that the initial CPU tempreture is 70 C . My fans speed is around 3500 rpm. after I open a one week the tempreture become around 66 C and the fan speed still remind 3500 rpm. Is this tempreture is normal or abnormal. HELP!!!
P4 2.8E is the prescot which is known for the fact it heats up alot, I think you temps are more or less on the dot when it comes to prescot. doubt it has anything to do with your mobo.
I am not sure I agree with that assesment. No two ways about it, presscots run hot, but that seems too hot, even for them. Lets run through some basic checks.
Have you removed and reapplied heatsink with some artic silver?
Do you or a friend have another m/b to test chip ( I had a overheating issue with P4C 3.0 and it turned out to be the m/b.
Try these and report back, we can go from there.
I have already remove heatsink with some artic silver, I put my hand near the cpu fan, I not feel any hot air. I heard from my friend that maybe the motherboard temp senser is too sensitive until not accurate, got this probilty or not?
<P ID="edit"><FONT SIZE=-1><EM>Edited by shiroamada on 05/30/04 11:53 PM.</EM></FONT></P>
sure lol, just replace it. Personally, I would want to make sure it is the fault of the mobo before I sent it back and cost $ to the maker, vender and myself (shipping) but hey that is just me. No wonder the prices are so high, he he, alot of us novice system builders seem to be jumping the gun and sending things back that may (or may not) work. I would try the simple thing and double check everything first, including reading up on the chip a bit.
peace
