A month ago my computer started acting funny. I normally leave my computer on 24/7, except when there are electrical storms coming through - then I shutdown and unplug it. Recently when I'd come home or turn my monitor back on my computer would be froze. I'd press the caps lock key to verify.
Now when I play games I notice it happening a lot more. The last time I played Warcraft III I ordered a unit to move and his response kept looping over and over and well as everything else locking up. Again I'd hit the caps lock key to verify that it was locked up.
Today I began by running some tests and I'm pretty sure I know what the problem is but would like some feedback.
I tested my memory today. When I did it would freeze at test 2. So I removed one chip and placed the other chip in it's place to get the same result, freeze at test 2.
Then I try switching dimms and chips and so on.. each time, freeze at test 2. I've never heard of 2 chips of ram going bad at the same time so I'm convinced it's the motherboard.
Thanks in Advance,
Onslaught
Thanks in Advance,
Onslaught
