Problem with GA-7DXE mobo and AMD XP CPU
ven0m
Ok, here is the thing. My bios CPU clock is set to 100 right now (default). But when it is set to 100, I see that it writes that i have 1250 instead of 1650 (i got amd xp 2000+ cpu).Now, i tried changing jumper to 133 on the mobo. However, after i did, my Monitor didnt turn on. When i changed it back, it works fine.
I tried setting bios cpu clock to 133. It works fine, and writes AMD 2000+, 1650 mhz just like it should. But when i reinstall windows, after installion finishes itself, and i restart the pc in order to start windows, i get blue screen.
Could anybody tell me how to resolve this ploblem?
rook
401
A <A HREF="http://www.giga-byte.com/Motherboard/Support/BIOS/BIOS_GA-7DXE.htm" target="_new">BIOS</A> update may help. Also what speed of memeory are you running?
<A HREF="http://www.anandtech.com/mysystemrig.html?id=23900" target="_new">System</A>
<A HREF="http://service.futuremark.com/compare?2k3=2072215" target="_new">3DMark03</A>
