Archived from groups: alt.internet.wireless (More info?)
Can anyone please help or advise?
I have a D-Link router DSL-504 connected to give me ADSL connectivity. This
has an IP address of 192.168.0.1. This also acts a a DHCP server.
I want to connect a Netgear WGR614 Wireless AP and router to this. The
Netgear has a default IP address which is the same as the D-Link. Should I
change this default before I connect it?
I expect the DLink would assign it the next IP address which would be
192.168.0.5 or should I just connect it? Even if I change the IP address to
something else the DLink could still try and assign something different.
"Cliff" <cliffj_green_nospam@hotmail.com> wrote in message
news:ck2u27$8v$1@titan.btinternet.com...
> This
According to the installation guide, the DSL-504T has a default IP address
of 192.168.1.1.
> Should I
> to
> Any advice appreciated.
> Thanks,
> Cliff
Are you using the Netgear router as just another AP but you have the Netgear
on hand, or are you trying to setup a second subnet (LAN)?
If you are just using the Netgear as another AP, change its LAN IP address
to be different than the D-Link router and outside the range of addresses
used by the D-Link's DHCP server. The address must be 192.1678.0.x if
that's what the D-Link is using on the LAN. Then disable the DHCP server on
the Netgear. Don't use the WAN port on the Netgear. Connect from a LAN
port on the D-Link to a LAN port on the Netgear (normally you would use a
crossover cable on a switch-to-switch connection, but the Netgear has
Auto-Uplink, AKA Auto-Crossover).
If you are setting up a second subnet, then connect a LAN port on the D-Link
to the WAN port on the Netgear. Change the Netgear to use a different
subnet address (not 192.168.0.x) like 192.168.2.x on its LAN. Keep the DHCP
server enabled on the Netgear.
Thanks for the advice but I am more confused now!
I want to keep the D-Link which is a cable ADSL router only and connect
the Netgear to it so that I can have wireless access for a laptop and
PDA.
If I change the range of IP address to be outside the DHCP range of the
DLink will it be able to see it? Id I disable DHCP on the Netgear will
the PDA and laptop be able to connect over wireless and get an IP
address?
Sorry if I am being a bit slow here, I am obviously missing something.
I don't know if you still need this info, but here goes.
Attach the Wireless access point to your ADSL modem, use a LAN port on the modem to the WAN port on the AP. Give the AP an IP address that is on the modem IE. the modem is 192.68.1.1, you can give the modem an IP address of 192.168.1.2, then setup the AP DHCP server to issue an IP range of 192.168.2.x. Even though they are on different subnets, the AP will hand off the traffic to the modem. Hope this helps.
I have my Linksys WRT54G setup to receive a DHCP address from my DSL modem. I assigned a subnet of 192.168.50.150 to my Linksys and set it to issue IP's in that range. My modem is set to 192.168.0.1 My AP shows the 192.168.0.1 as the DNS server.
