Tom's Hardware Forums » Motherboards & Memory » General Motherboard » Having System shut down Need Help
Word :   Username :
Bottom
Author
 Thread : Having System shut down Need Help
Profile: stranger
More Information
I am at wits end here. I have been experiencing system shutdowns for a while. I don't know what else to do.
Running Windows XP. I have a Shuttle MN31N MoBo. AMD 2600+ Thorobread w/stock cooling (not over-clocked). Leadtek GeForce 5600 Ultra (Not over-clocked). Maxtor 80 gig drive with os loaded and a Western Digital 40 gig drive. 1 gig ram Danelec. Running MBM 5 I see my system Idles at 45c - 52c. Under load it goes up to 70c or so. Too hot I'm sure. I have three case fans 1 on side blowing in, 2 in the rear blowing out. My sys starts fine but after running 3d apps for a while i get shutdown and restart. This happens often and is driving me insane. I have removed the 5600U and am now using the GeForce 4mx included on the board, still having shutdown issues. Temps still the same since removing the 5600U. Any ideas?
Related Product
Profile: old hand
More Information
Those temps do sound a bit high, especially if you're not overclocking. Have you removed and remounted your CPU heat sink/fan? If you used the stock AMD cooler and left the little gummy pad on the bottom, scrape it off and get some heat paste and remount it. That should bring your CPU temps down.
Also check to make sure you are running proper CPU voltage. I think that chip uses 1.65 volts.
Finally, make sure you don't have one of those nasty viruses that likes to shut your computer down. Run a virus check and make sure you have all the Windows security updates (I'm assuming you're running Windows...)
Scout
700 Mflops in SETI!
Google Ads
News
GPS can help give early warning of tsunamis
Published on June 30, 2006
Using GPS (global positioning system) data to measure how points on land move following an undersea earthquake could help geologists decide if the tremor will cause an ocean-wide tsunami. Read more
Microsoft updates Vista in latest piracy crackdown
Published on December 15, 2006
Microsoft released an update to Windows Vista that will shut down unauthorized versions of the OS that allow users to skip the product's activation system. Read more
Millions Hit In Southern Florida Power Outage
Published on February 26, 2008
People in southern Florida were hit with a massive power outage after two nuclear reactors spontaneously shut down. The outage centered on the Miami-Dade area, but also extended to some parts of Broward County. Nuclear Regulatory Commission reps say the reactors were probably responding to a weird reading in the power grid and add that everything should be back to normal shortly. Read more
A SWAN to guide blind people
Published on August 16, 2006
Researchers at the Georgia Institute of Technology have developed SWAN (an acronym for "System for Wearable Audio Navigation"), a wearable computing system to help blind people navigate in unfamiliar environments. Read more
Latest Reviews & Articles
Shuttle's X27: Can Atom Handle Vista?
Published on October 08, 2008
In the horsepower race between Intel’s and AMD’s quad-core chips, the Atom processor is an everyday hybrid. Shuttle took it and created a pint-sized small for factor box. Is it powerful enough to be your daily-use desktop, though? Read more
Do New Drivers Really Boost Performance?
Published on October 07, 2008
How much extra performance can you get from a simple graphics driver update? And what sort of gaming gains can you expect from a high-end graphics card when you overclock your CPU? Read more
Best Video Cards For The Money: Oct '08
Published on October 06, 2008
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. At the end of the day, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Atom, Athlon, or Nano? Energy-Savers Compared
Published on October 03, 2008
We compared Intel’s Atom 230 and VIA’s Nano L2100 processors hoping to find the best product for low-power applications. VIA is in the vanguard of performance. Is this enough to beat Atom? Read more
