Well, then download the latest patches for the game and if you're running it in Vista or Windows 7 then change the compatibility mode to Windows XP...
Hope that helps...
hi dear, i have the same problem...can u please tell me how should i change the compatibility mode to widnows xp?!
PS. i am running the game in windows vista business..
Right Click on the file that launches the game(maybe Carbon.exe) and go to properties.
You'll see a Compatibility tab
oh yes i figured it out and changed the compability to windows xp but then i think the patchs i downloaded are not working properly, cuz still when i open the game its written 1.2 on top right hand of the screen.......after updating the patchs its supposed to be 1.4 right?! cuz i downloaded patch 1.3 & 1.4...
so how should i actually make the patchs work?!
