Hello
Im having a problem with my PC in the moust unpleasent moment as I can’t do my college work and I cant afford new PC in the next 4 months, so any help with my problem will be greatly appriciated.
OK.
Here is my problem.
When I work and that’s usualy using Internet and Office XP (and espesaly when Lavasoft AD-Aware is running) my PC is turning off. Whell its not turn off exactly because CPU, GPU and PSU fans are still working but the monitor is touring on stand by. When this happens I can’t do restart so I have to push power on/off button on the case turn the PC off. If I try to turn in on afther that NumLock and CapsLock indicators on the keyboard will flash for a second again only CPU, GPU and PSU fans works but the system is not starting.
When I opened the case four led diodes that are on my MSI mainboards were lightning red. In the manual explanation for this is “The procesor might be damage or not instaled properly. Damage/discharge lithium batery”
I doubt that the problem is procesor because the PC will never start if the procesor is damaged of instaled properly.
Iv also changed lithium batery but the problem remained.
And another thing. PC Alert 4 somethimes shows that CPU and system tempetarure were 78 C. Afther this restart the system and went in bios to see if that was the real temperature but the bios showed 32 C for procesor and 22 for system. PC Alert 3 that I got it with the mainboard cd always showed only few degriece difference beetwin bios and this program.
I have the latest drivers, bios and updates for windows. Iv checked for viruses with the latest updates for Pc-cillin 2002 and I didn’t find any viruses. Iv cheked every componets on other configuratios and they worked fine.
Now a frend of me told me that the cause of problem are condenzator on mainboard araund the procesor.
Iv inspected mainboard with my friend who work in service deppartment in a company that sells pc componets and we didn’t find any indicators on burned condenzators.
Lately I open the case and point some large room fan to blow air directly in the case. Iv notice that PC is working a lot more time before this problems occure.And I also notice that afther a failure if I reset bios PC is starting to work properly.
I tested all other PC parts on other machines and they worked ok.
If you know whats the problem please tell.
Thanks.
OK.
Here is my problem.
Thanks.
