I just built a new system with this mobo, and the following components:
AMD64 3400+
512 kingston ddr400
9800pro
80gb western digital hdd
480watt thermaltake psu
MSI cdrw
when the system boots up, there are infinate long beeps. I have tried swapping the graphics card. I assume that the cpu is properly installed as it went in really easy, and all seemed to fit using the default heatsink. all of the power/led chassis stuff is in correctly, the cmos has been reset. CPU and mobo fans are plugged in and working. The hdd is set to master and plugged into IDE1. Everything seems to be done, what could we be missing/what could be wrong?
Radeon 9800 Pro IceQ 128MB
AMD Athlon XP 1800
512 SDRAM
Shuttle AK32 Mainboard
Win XP<P ID="edit"><FONT SIZE=-1><EM>Edited by WildThing on 07/08/04 00:08 AM.</EM></FONT></P>
AMD64 3400+
512 kingston ddr400
9800pro
MSI cdrw
AMD Athlon XP 1800
512 SDRAM
