Archived from groups: comp.sys.hp.hardware (More info?)
We have some older printers at work that are no longer in service, and
I am going to be allowed to take one to use at home. We have two HP
Laserjet 6P printers and 1 HP Laserjet 2100 printer. The 2100 has the
network card installed and is newer and (I assume) more capable than
the 6P, so I would prefer to take the 2100.
Both 6P printers power up, print good test pages, and will print from
the parallel input.
However, the 2100 printer will not power up. Before I dismiss this
printer as a lost cause, are there any fuses or other common problems
that I should look into? I'm not really interested in paying much to
have it fixed as I probably won't use the printer a lot, but if it's
something simple I would prefer to go with the newer, more capable
printer (the network port would be a huge plus as would the 1200dpi
versus 600dpi max resolution).
Any tips would be appreciated.
Geoffrey Reynolds
