New system won't POST :(
Forum Motherboards & Memory : General Motherboard - New system won't POST :(
Hey guys, I just got all my computer components delivered and tried to put everything together but it won't POST. As soon as I boot the computer, it says:
Verifying DMI pool data...
NVIDIA Boot Agent 197.0462
Copyring blah blah blah
And after a long while of doing nothing it goes to:
PXE-E61: Media test failure
PXE-M0F: Exiting Nvidia boot agent
Any ideas? I tried mashing on F12 and Delete, but it just won't let me go to the BIOS setup. Thanks guys!
Rig info:
A64 3400+
MSI K8N Neo Platinum
2x Corsair 512MB XMS DDR PC3200
Seagate 200GB IDE
eVGA 6800GT
LiteOn DVD+/-RW
Sponsored Links
Delete should get you into BIOS, but you need to be pressing it sooner I reckon.
I assume you've put your Windows (presumably XP?) CD into the CDROM, and it's connected happily.
Do you get a hard drive activity light come on at all?
Epox 8RDA+ V1.1 w/ Custom NB HS
XP1700+ @200x10 (~2Ghz), 1.4 Vcore
2x256Mb Corsair PC3200LL/1x512Mb Corsair XMS PC4000 2.5-3-3-7
Sapphire 9800Pro @412/740
Reply to ChipDeath
Turn off PXE Boot rRom, or Boot by Lan, or whatever it's called in yoru BIOS.
But yeah, should be hitting delete noticably before it gets to this point, unless this is some really strange motherboard.
Reply to etp777
Thanks for the help guys. I managed to get into BIOS and I don't see anything set to boot rRom/by LAN. The CD and HD both seem to be showing activity. I just tried putting in the XP CD for the first time and it started setting up the devices (I think), but when it asked me if I wanted to install windows, my keyboard wasn't responding so I had to reset. My computer started beeping repeatedly so I reset it, and now it keeps getting stuck on Verifying DMI Data Pool. Please help! :(
Reply to fobtastic
Try resetting the CMOS. There's a jumper below the motherboard clock battery. Unplug power, flip power switch on and off to discharge psu, and then jump from 1&2 to 2&3. Leave that for 10 seconds and then rejump to 1&2. Plug PSU back in, turn on comp, should be able to get into bios with defaults loaded. I'm describing the procedure from memory, so check in mobo booklet first.
"It's too late now anyway. That song is stuck in my head and the only way to get rid of it is to blow it out. With a bullet!! - Carl
Reply to Obtuse
Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > New system won't POST :(
There are 1182 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
