Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Internet connection problem
Forum Windows XP : Windows XP General Discussion - Internet connection problem
Anybody heard of an XP-Pro problem where the user types in a web address it doesnt work but if you enter the IP of the same site it will work...
Trust me I know what I'm doing... ooops, grab the cat...
Sponsored Links
Check your file called <b>HOST</b> (no extension) in <b>Windows\System32\Drivers\etc</b>. Probably it's been blocked by some softwares (eg. Kazza-lite) assigned a nulled IP (127.0.0.1) ). If it is, you can unblock it by delete the reference in the file.
:smile: Good or Bad have no meaning at all, depends on what your point of view is.
Reply to khha4113
- 0 +
If that isn't it, you have a dns problem. Check your dns config if you are using a static ip. If you are using dhcp you might be recieving bad dns information.
If you are behind a home router your primary dns should be the router and the secondary should be your isp's dns controller. You can type in ipconfig /all at a comand prompt to see what your current primary and secondary dns is.
<A HREF="http://www.folken.net/myrig.htm" target="_new">My precious...</A>
Reply to folken
There are 650 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
