I believe I have some trouble with a parasitic connection to ground on my motherboard. May this be controlled by measuring the voltage on the power good wire between the PSU and motherboeard? I have a Abit NF7-S motherboard and measured the voltage on the powergood wire to be 4,7V.
The problem was discovered when I installed a new PSU (NorthQ NQ4001) and it shut down the power imediatly after I pushed the on button. I now use my old PSU which still works.
The rule of thumb is + or - 5% on rail voltages. Your NorthQ is out of spec. I doubt it's a MB ground. Try that supply in another rig and see what you get.
Abit IS7 - 2.8C @ 3.4ghz - Mushkin PC4000 (2 X 512) - Sapphire 9800Pro - TT 420 watt Pure Power
Samsung 120gb ATA-100 - Maxtor 40gb ATA - 100
Sony DRU-510A - Yellowtail Merlot
