Hello, first my system:
- 1 x 350W Power Supply
- 1 x AMD Athlon XP 3200+ 512K 400FSB BARTON SOCKET A CPU
- 1 x DFI INFINITY NFORCE2 ULTRA400 SOCKET A DUAL DDR AGP 6PCI SATA SOUND LAN 1394
- 3 x SAMSUNG 512MB PC3200 DDR400 RAM
- 1 x SEAGATE BARRACUDA 7200 80GB HD ATA/100 HD
- 1 x VIEWSONIC G90FB 19IN MONITOR
- 1 x ATI RADEON 9800 PRO 256MB
- 1 x LITEON DVD+-RW DUAL 8X4X/8X4X CDRW 40X24X30X
- 1 x Creative Sound Blaster Live! 5.1
I just got this computer a few weeks ago, except it had INFENION ram. it crashed a few times in windows (just restarted on its own), and kept crashing to desktop in Far Cry and Warcrag III TFT, the only games I installed. Anyway I did memtest86+ and it gave like ~33000 errors, so I concluded that I had bad ram. I sent that ram back, and got replacements the above listed Samsung ram. The ram I have (http://www.ncix.com/products/index.php?sku=9545&vpn=SAMSUNG3200-512M&manufacture=Samsung), and my motherboard (http://www.ncix.com/products/index.php?sku=11304&vpn=INFINITY-NFORCE2&manufacture=DFI). So finally yesturday I got the new ram, I put it in and after playing farcry for 10-15 minutes it crashed to the desktop. So I ran memtest86+, and it gave ~4500 errors in one pass. I couldnt believe I got bad ram again, so I thought it was my mobo. Over the next 3 hours I did this:
1. Took out all the sticks, then took one and placed it in one slot. Ran memtest86+, and it passed 1 pass ok.
2. So I took this stick and put it in a second slot, ran Memtest again, and it passed 1 pass w/o errors.
3. Then I took this stick, and put it in the 3rd ram slot, ran Memtest, and it passed the test w/o errors. So I concluded that my mobo is ok.
4. I took this stick out, and then I took the 2nd memory stick, and placed it in one of the slots. Ran memtest, and after 1 pass, there were no errors.
5. I took this stick out, and I took the 3rd stick, and placed it in a different slot (than above), and ran memtest. After 1 pass there were no errors.
6. Then leaving the 3rd stick in, I took stick #1, and placed it in the 1st slot. That means now I have 2 sticks in. Ran memtest, and after 1 pass there were no errors.
7. Leaving all sticks in, I placed stick #2, and put it in the remaining (middle) slot. Ran memtest, and after 1 pass it gave almost 700 errors at test#6.
8. Ok wtf?? So I took the other 2 stick out, leaving just the stick #2, in the same (middle) slot, and ran memtest. One pass returned no errors.
9. Now I put stick #3, into the first slot, and am running memtest now. ~500 errors so far (2 @ test #4 and the rest @ test #6).
10. I put the 2 sticks that worked before (in 6), but this time one of the sticks was in a different slot, and it gave two errors at test#2. At which point I just gave up and shut off my computer. it was already pretty late.
Ok so what is going on with my computer?
This is what Memtest has to say about my settings:
Chipset: nVidia nForce2 SSP / FSB: 200Mhz
Settings: RAM : 200Mhz (DDR400) / CAS: 2.5-3-3-8 / Dual Channel (128 bits)
The only difference was when I had one stick at a time, it said 64 bits at end.
Are these settings right? I thought my mobo was FSB: 400Mhz. and shouldn't the RAM be running at the same freq. I dont know much about these ram settings and FSB and timings and such. Please keep in mind this, when posting suggestions. From searching I've read many people say "make sure timings are tight", or "change or lower your ram voltage" and "change ram clock". I am not sure exactly what all these things mean (especially the timings thing). But I guess you change them from BIOS?
Also in the BIOS there are some settings for RAM that have options like "Normal" or "Default" and "Turbo" and "Expert" and such. I've read that changing some setting from Turbo to Default fixes some problems. So if you have anything to say about this please do share
Also from searching around, people have said that to others that my mobo is good "just make sure you have revision 2" or something like that. Whats revesion 2? Is that a different version of the mobo, or just newer BIOS? How do you find out which "revision" you have? Also I've read to make sure I have newer BIOS. I probably have the ones that came with the board. Could this be the problem. Also hw do I check which bios I have, and which ones shouold I have?
What could be the problem?
Please help me fix this. Any ideas/advise/tips are greatly appreciated.
Thansk, a lot,
Latem
<P ID="edit"><FONT SIZE=-1><EM>Edited by Latem on 08/20/04 01:05 PM.</EM></FONT></P>
Thansk, a lot,
Latem
