Sign-in / Sign-up
Problem with Bad Company 2
  • PC gaming
  • GPUs
  • Video Games
Last response: in PC Gaming
June 6, 2010 2:31:41 PM
I keep randomly getting kicked for "Punkbuster: Heartbeats Stopped"
I've read where people say it could be related to heat problems with either the CPU or the GPU... Sometimes it kicks me right after I get in, and sometimes I can play for an hour or two before it does this.... I just got kicked and had been playing for over an hour and my GPU Temp was 65c. (Im running a XFX GTX 285 black edition) Is 65c hot or is this a normal temp under load for this card?
Anyone know what it could be?
More about : problem bad company
June 6, 2010 4:15:39 PM
no problem with the temp, go to this directory c:\windows\system32 and deleted this file: PnkBstrB.exe, reboot the computer and it will download and install it, tell me if it helps
m
l
June 6, 2010 8:27:45 PM
That file is not in the folder.. I even searched for it with no results.
m
l
June 7, 2010 6:28:16 AM
You may have something running in the backround that is hurting it. Stop all of the unneeded startup programs and disable antivirus next time you try punkbuster...
m
l
