Another GTA IV problem... that shouldn't be
I've just gone out and bought a 9800gt to upgrade gaming performance.
I'm running a Pentium D 2.8ghz processor and the minimum req for GTA IV is 1.8ghz. I should be able to run graphics close to high shouldn't I? medium at least. Having everything on low and res down to 800x620 I'm sadly getting 10-12fps. only link to the problem i can think of is too low power. My PSU puts out 300w, could i be choking the setup?
any help would be great
3 answers Last reply
More about another problem shouldn
  1. What brand PSU? It does sound like your PSU is underpowered for that card.
  2. Its just the stock HP 300w, but I've been told an underpowered system will just crash, rather then lack perfomance
  3. GTA IV is dependent upon multiple cores, usually more than 2 makes a difference.
    I had an Athlon X64 4200+ X2 (which is similiar in construct to your Pentium D) and it couldn't play it above 15 fps period, even on low settings.
    When I upgraded to an Phenom II X3 720 BE, things improved. But even then, I still had to upgrade my GPU as well. I had an HD 3870 and with the Phenom II, I was getting on average around 35 fps with the demo. I'm now getting around 40-45 and that's on high, but not full high.
    It also depends on how much memory your GPU has because the more details you turn up, the more memory it takes. One thing to cut down is the view distance. I have it set around 30 I believe which still gives you a pretty good view.
    Also, how much memory do you have and what is it's type and speed?
PC gaming Video Games
