Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Connecting to 2 houses via wireless?
Archived from groups: alt.internet.wireless (More info?)
Hi,
I have a wireless router - that is inside my house, so not much signal
getting outside the 4 walls. There is alos my mate - who owns a hourse
20 odd metres away. The idea is - I get a 1 or 2mb line, and then via
wireless gets access to the line and we share the cost.
Question is - best method. Is it best to create a small ariel that we
can place on the facia boards of our house, that can connect - or what
about 2 aerials in the loft. What wireless equipment would be best - any
websites that have done this before?
Cheers
Scott
Sponsored Links
Have you got windows facing each other ?
If so place your wifi on the window sill, your friend can place a usb wifi
adapter on this window sill and you are in business.
Failing that placing your wifi in the loft should work too.
Probably the best wifi routers are Draytek 2600 range, not cheap though.
I have good results with Orinoco USB adapters, works trough two sets of
double glazed windows and 75m of space.
Regards,
Martin
Reply to Anonymous
- 0 +
We have windows that sort of face each other - but the loft option looks
better. If we go for the loft otions thats the equipment thats vest.
I already have a wireless router - so was thinking of placing a wireless
bridge in my loft. Am I then also to papce a wireless bridge in his loft?
His main pc is a laptop so was thinking of just putting a wireless
pcmica card in.
Scott
Reply to Scott
Mine work well trough the windows at acute angle, even though one of the
windows is leaded.
Tiled roof will limit the signal.
Your wifi router *should* do the job, you may have to experiment with
placing it.
Standing a right angled card covered with silver foil behind the antenna(s)
will help direct it towards target.
USB adapter works better, easily positioned for best signal, higher is
usually better, half an inch can make difference.
PCMCIA card may not work if you have weak signal and you can't move the
laptop.
Regards,
Martin
Reply to Anonymous
If you have a clear line of sight then you could use a combination of
HiGain antennas. A combination of 9dBi (omni) and 14dBi(directional)
could give you a point to point connectivity of approx 1 mile.
You will need two wireless bridges at two ends to connect antennas.
The Linksys 54G wireless access point can be used as a bridge also, so
you can make a link between two buildings.
Once you hav elink between two locations, you can connect it to the
local routers at both ends (need not be wireless). This is just one
option. Another option is to use just an wireless router (or access
point if you already have a router) and attach a omni directional
antenna.
You can find the details of antenna at www.hawkingtech.com or
www.netgear.com or search for Hi Gain antennas.
Hope that helps.
Reply to Anonymous
- 0 +
Use a D-Link DI624 wireless router,
Through a woodframe wall(gyproc inside, vinyl siding outside), then the
old maple tree, 60 meters to 2nd building, thru 2 walls of 2nd building
to a card (DWL G520)in a desktop. Works great, set it up last winter,
thought the leaves onm the maple tree would be a problem, but works
fine. No extra attatchments or foil on either end.
Admittedly, the signal (or "line of sight" )goes thru the walls more or
less perpendicular
Cheers
Ed
Reply to Ed
Scott <slewis1972@lycos.co.uk> wrote in message news:<2teq2sF1ukvfiU1@uni-berlin.de>...
> Hi,
20 m?
Is there some reason (a paved road between you, for instance) that you
can't dig a trench and bury a cable?
Reply to Anonymous
There are 1101 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
