Isp or Modem Problem?
Last response: in Video Games
Can a bad modem/isp/bad harddrive? be a problem with bad registration of shots
I always ending up restarting my modem every 2 games to get good registration of shots then my shots dont register but their isnt no frame lag this happens for about every fps game my vent ping is steady and good and so is my ingame ping i am directly connected to my router but i have still have the same problem
System Specs
Manufacturer:
MICRO-STAR INTERNATIONAL CO.,LTD
Processor:
AMD Athlon(tm) II X4 620 Processor, MMX, 3DNow (4 CPUs), ~2.6GHz
Memory:
3328MB RAM
Hard Drive:
160 GB
Video Card:
NVIDIA GeForce 9600 GSO
Monitor:
Plug and Play Monitor
Sound Card:
Realtek HD Audio output
Speakers/Headphones:
Keyboard:
USB Root Hub
Mouse:
USB Root Hub
Mouse Surface:
Operating System:
Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.100216-1441)
More about : isp modem problem
It means that my crosshair is on the guy and ill burst a few bullets into him and its doing low to little damage trust me its not aim first 2 games i get 2-3 kill death ratio then after that i can barely maintain 1 kill death ratio so i restart my modem and im getting a 2-3 kill death ratio
What is your download/upload speed from ISP, www.speedtest.net will give you some much needed info, to play games online you should have minimum 3Mb connection download/1Mb upload, if anyone else in the house goes online at the same time as you and are downloading whatever, you should run about 6Mb minimum.
I use RR as well, in cincinnati, ohio. It almost sounds like your modem is dropping packets, I would go to a local store and ask them to swap it out... Or if you call for support in the pre-recorded message choose the option for VOIP (even if you don't have VOIP), you will bypass L1 and L2 support groups that don't know SH**. L3 are the network guru's that know what they are doing.
your ping rate is a little high for it's speed, probably packet loss. Check ISP for a stability test, they may need to bring the speed down so you get stable line (no packet loss), might drop to 10Mb but should be fine for gaming after this.
Ask the community
