Yes No
Ads
Beginner needs help
Forum Wireless Networking : General Discussion Beginner needs help
Archived from groups: alt.internet.wireless (More info?)
I'll soon be traveling in my motor home and want to try WiFi but I am a
total beginner.
I want a high gain external antenna. I can attach the antenna to my TV
antenna so it rotates, but I have no control over vertical or horizontal
rotation. Do some WiFi locations use vertical polarization and other
horizontal polarization? Any recommendations?
I want high power and am looking at the Senao / Engenius NL-2511 CD+EXT2
card. Is this a good choice? Any other recommendations?
I think I saw some software that helps locate WiFi locations. Is there any
free software? Or recommendations?
Thanks for any help,
Dennis
Reply to Anonymous
Most use vertical polarization. The Engenius is a 200mw card which is 23db
so the max legal antenna would be a 13dbi = 36 or 4 watts for a point to
point configuration. The 200mw is really your transmit power and what you
are going to be interested in mostly is receive power so I would go for a
bit higher gain antenna and a bit less radio. If you want to really get it
going try one of these http://www.moonblinkwifi.com/pd_ydi_24.cfm with a
100mw radio = 34 db. Problem is, yoou might not want to drive around with it
up....:0). Orinoco are a really good card too.
Netstumbler is probaly the software you want......its free
"Dennis Vogel" <dvogel@sprynet.com> wrote in message
news:Xx8dd.1168$5i5.242@newsread2.news.atl.earthlink.net...
> total beginner.
> Dennis
Reply to Anonymous
On Tue, 19 Oct 2004 13:21:59 GMT, "Dennis Vogel" <dvogel@sprynet.com>
>total beginner.
Welcome to "Learn by Destroying". You've come to the right place.
Why? Are you going for the DX distance record? Perhaps you expect to
find yourself too far from the hot spot? High gain antennas are a big
help, but have some limitations. The big one is that they require
fairly low loss coax cables and weird "pigtail" adapters. Low loss
implies either fairly short thin cables, or longer big fat inflexible
ugly cables.
Yes, but most of the hot spots are vertically polarized. Horizontal
polarization tends to used by point to point links (in order to
minimize interference with other users).
Maybe you are going for the distance record. Yes, the Senao cards are
quiet good on both the power output and receiver sensitivity. The
offer a suitable connector for attaching a pigtail, coax, and then
antenna. However, you have a problem. Your radio and antenna are
going to be rather seperated by many feet of coax. That's very lossy.
You may find that all the money you spent getting a high power radio
is wasted in the coax loss. The antenna gain can help recover some of
that, but methinks keeping the loss low would be best.
The NL-2511 CD+EXT2 is a PCMCIA card which will need to used in a
laptop. Do you have a laptop? Visualize a 1ft piece of 1/8"D
flexible coax cable coming out of the PCMCIA card, connecting to a
1/2"Dia LMR-400 stiff coax cable going to the roof. Do you really
want that?
Methink you find a USB radio more useful. Instead of a big fat lossy
coax cable run to the roof, you have a considerably smaller USB cable.
The official maximum run for USB is 16ft which methinks should be
sufficient. The radio would be mounted in some kind of waterproof
package (plastic electrical outdoor box). The RF will go right
through the plastic box, so no need for an extra antenna. You may
need to solder a pigtail to the radio if you insist on a high gain
antanna. The big advantage of USB is that the radios are cheaper than
other forms.
If 16ft or the insipid power output is an issue, there are also
ethernet connected radios. (WAP54G, DWL900AP+, DWL-2100AP, etc) that
have a "client bridge" mode. There's also a class of device called
"game adapters" that will do the same thing. Instead of USB cable,
you have an ethernet cable. The boxes usually (not always) have
external RF connectors that will go to your high gain antenna. You'll
need to supply power to the box, usually via a PoE adapter or just
with a seperate pair of wires to the power connector. As before, some
repackaging will be required.
You can also buy pre-packaged antenna/radio combinations designed for
outdoor use. See:
http://www.ydi.com/products/wireless-internet.php
in the Client Premisis Equipment section. These are rather expensive
which is why many users roll their own.
http://www.sveasoft.com/articles/armored/
(this is actually an access point, not a client radio, but the
construction and technology are similar).
I'll assume Windoze as Mac and Linux users usually specify what OS
they're using.
http://www.netstumbler.com
http://www.netstumbler.org
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 AE6KS 831-336-2558
Reply to Anonymous
Thanks Jeff, a lot of good information. Thanks to Techmeister too.
Dennis
>total beginner.
ugly cables.
want that?
other forms.
outdoor use. See:
any
they're using.
Reply to Anonymous
Jeff, thanks again. I'm starting over. Sounds like I need a USB box and
about 10 or 12 feet of USB connector.
I can put the USB box in a cabinet just inches from the roof and a fixed
antenna. From what you say it sounds like that would work a lot better.
Can you recommend a decent vertical antenna?
Can you recommend a USB WiFi box? And where to purchase these items?
Dennis
> >total beginner.
> ugly cables.
> want that?
> other forms.
> outdoor use. See:
any
> they're using.
Reply to Anonymous
> total beginner.
As an RVer in this area, you will find one of three situations:
1- You are stopped near a McDonald's or Starbucks where the signal is strong
enough that you don't need a high gain antenna.
2- You are in a campground that provides WiFi in the park. Here an
external antenna would be useful, not necessarily a high gain antenna.
3- You are roadside, or in a campground with no WiFi.
Without cooperation from the WiFi source, like a high gain antenna
pointed in your direction, you are probably out of luck. Signal
probably won't go past the limits of the RV park.
#3 is a guess, and could collide with the experience of some
signal poachers, but I suspect the range is no more than a half mile.
#1 and #2 are both satisfied by a USB adapter, like Jeff suggests. Maybe
permanently mounted outside, maybe just run out through the roof vent when
you want it.
#1 Starbucks or McDonald's require a subscription. #2 might be
subscription, but is most likely pay-per-night. #2 might be expensive
enough that you hang out at a McDonald's to get your internet fix every day
or so.
SBC/Yahoo just announced a $1.99 per month add-on for WiFi for their
existing DSL customers which covers some McDonalds, but I see you are with
Earthlink. If you have T-Mobile cellular, they have an add-on covering
Starbucks.
If you subscribe, you have some locator guides as to where to expect the
next WiFi outlet. I used to stay at KOA Kampgrounds when travelling on
ad-hoc vacations for the same reason. I could find a reasonable campground
in roughly the area where I wanted to be the next night.
http://www.koa.com/hotspotzz/index.htm shows wireless KOA sites, powered by
http://www.hotspotzz.com/ which is a subscription service that has
locations at KOA and some trendy coffee shops.
Reply to Anonymous
Don't put the USB device in a "box" made of wood - just plastic would be OK.
but you want it positioned with the least amount of "stuff" - wood, RV
shell, cabinets, etc - between the antenna and the signal. (That includes
trees between you and the access Point.)
You can get powered USB extensions that allow you to go up to 80 feet or so
with "active USB cabling"
http://www.compusa.com/products/pr [...] pfp=BROWSE
Consider getting a USB adapter that also allows for an optional external
antenna. That way you could add on an external antenna if necessary. Or you
could buy a less expensive USB adapter initially and if it does not prove
successful, dump it and get one allowing an external antenna.
http://www.buffalotech.com/product [...] tegoryid=7
Of course, if you go with an external antenna, you want to minimize the coax
length to reduce power loss. Suggest you look at pigtails and antennas at
www.fab-corp.com
Now if you wanted to go low-cost and low-tech, you could configure a DIY
"tin cantenna" - a do-it-yourself antenna made out of a relatively low cost
USB dongle (such as the 802.11b D-Link DWL-122 - about $10 if you shop
around - w/ 7 ft extension cable.) and an old empty 11 oz coffee can. Of
course you have to do some positioning if the signal is weak, but if the
signal is weak, you will do that anyway. (Maybe a DIYtripod or portable
holder for when you place it out a top vent??)
http://members.cox.net/tulsaalston [...] tenna2.htm
http://members.cox.net/tulsaalston [...] ter%20.htm
Good luck!
Bob Alston
bobalston9 AT aol DOT com
news:bhcdd.1358$5i5.850@newsread2.news.atl.earthlink.net...
> Dennis
>> >total beginner.
>> Welcome to "LearnbyDestroying"
>> ugly cables.
>> want that?
>> other forms.
>> outdoor use. See:
> any
>> they're using.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.778 / Virus Database: 525 - Release Date: 10/15/2004
Reply to Anonymous
On Tue, 19 Oct 2004 17:37:11 GMT, "Dennis Vogel" <dvogel@sprynet.com>
Yeah, methinks that would would work. I still prefer the ethernet
client radios instead of USB because of the ease of connecting
external antennas. However, others have pointed out reflector type
antennas (coffee cans, tuna cans, sheet aluminium, carboard covered
with aluminium foil, etc). Lots of fun playing with antennas.
Well, by "cabinet" I hope its something RF transparent (plastic, pvc,
glass) and not wood, concrete, or anything that might get waterlogged.
2.4GHz does not go through water or anything wet. However, that
applies only if you use an internal (patch) antenna. If the antenna
is external, whatever you want.
Sure, but you need to tell me how far you wanna go, over what kind of
terrain, whether you have line of sight, and some clue as to hardware
on both ends. They, we do a fade margin calculation:
http://www.ydi.com/calculation/som.php
to see how reliable the connection will be. 10dB is the absolute
minimum fade margin. An omni antenna will be the easiest to deploy
and install, but since you have a rotator, why not use it? Look at
patch (panel) or reflector (dish) type antennas:
http://www.fab-corp.com
I have a few customers in trailer parks and have a little experience
in making them work. The metal boxes are pure hell as they create
reflections that cause multipath problems. I found that shooting
across the trailer rooftops is a loser. The best results so far was
hanging the radio in a nearby tree, about 4 ft above the roof line.
That was a ethernet client radio, not USB as the cable would have been
too long. I've had to use directional antennas not to get sufficient
gain to talk to a distant access point, but to reduce or eliminate the
reflections caused by bounces from behind the antenna. An omni will
pickup these reflections with equal strength, while a directional
antenna will pickup almost nothing from behind the antenna pattern.
I'm not sure what to recommend. I prefer the tiny "dongle" type of
USB radios because they are easy to modify and install at the focus of
a dish, coffee can, or other reflector. The larger boxes are easier
to mount on a roof (inside a plastic NEMA box), but require soldering
to attach a pigtail. I have a Netgear MA-101 USB radio that I use
with Netstumbler in the car to map access points. I also have a Dlink
DWL-122 for the same purpose. I really can't recommend any USB radio
simply because I don't use them enough to get sufficient experience.
Reply to Anonymous
Jeff - A bit more about what "ethernet" connected radios can be used in
place of USB? Any that easily (no soldering) support external antennas
Bob Alston
"Jeff Liebermann" <jeffl@comix.santa-cruz.ca.us> wrote in message
news:1tvan01gsdvchdpksmpcncadchf16hd44k@4ax.com...
Reply to Anonymous
Thanks everyone for the great help. I settled on a YDI USB-Ant 2.4GHz 18dBi
Flat Panel USB Antenna.
I'm hoping to get free Internet access from time to time in my travels. Once
every three days will do.
Dennis
Reply to Anonymous
$169.00 for the YDI? The mini-usb in a can would be less than $30.
Hawking HWU54D Hi-Gain Wireless-G Directional USB 2.0 Network Adapter
http://www.hawkingtech.com/prodSpec.php?ProdID=208
HAI6SDP Directional 6dBi WiFi Antenna with a built in HWU54G Wireless-G
USB2.0 Network Adapter is ~$60.
Netstumbler would be your friend. Some libraries and some hotels offer
free service to their guests. If I only wanted access for an hour or two
every three days, I'd be inclined toward parking in Starbucks parking lots.
Clarence A Dold - Hidden Valley (Lake County) CA USA 38.8-122.5
Reply to Anonymous
On Wed, 20 Oct 2004 00:16:23 +0000 (UTC),
Yeah, it's expensive, but it works. Let's play dollars and sense with
the do it thyself method.
USB radio $50 (Netgear WG111)
USB extension cable 10ft $10
18dBi panel antenna $50 (Fab-Corp)
Outdoor NEMA 4 box $18
Pigtail (RG-188 to N-male) $12
Misc (mounting hardware) $10
$150
Close enough.
6dBi antenna gain is about what you'll get with a PCB substrate patch
antenna. Even a coffee can is better than that. 8dBi is what an
elevated patch antenna will deliver. 14dBi is about what you'll get
with 4 of patch antennas on a panel. Would you put that Hawking radio
on the roof of a camper? Waterproof?
Reply to Anonymous
On Tue, 19 Oct 2004 16:57:38 -0500, "Bob Alston"
>place of USB? Any that easily (no soldering) support external antennas?
An "ethernet" connected radio is just a client radio. Many access
points have client mode features (WAP11, DWL-900AP+, DWL-2100AP,
WAP54G, etc). There are also the various "game adapters", but these
require some care in selection. If they require the Ad-Hoc mode to do
bridging, they may not have a client mode feature. I'm too lazy to do
a survey of every possible client device, but if you have one in mind,
I can RTFM and try to decide if it might work.
The client mode bridges I listed above all have external antenna
connectors (R-SMA, or R-TNC). It's easy enough to attach pigtail
between the connector and an external antenna.
I don't consider the lack of a connector to be an issue. Make or buy
a pigtail from an N-connector and some thin coax (RG-188a/u or .141
semi-rigid). Remove whatever claims to be an antenna and solder the
coax end of the pigtail to where the antenna was connected.
What do you have against soldering? If you can build your own
antennas, you should have enough manual dexterity to do some
soldering. Like everything else, it does take some practice.
Reply to Anonymous
I talked to a salesman on the phone and they wanted $350.00. Another company
wanted $279.00.
I went to EBay and found one just ending and got it for $129.00 plus
shipping, or about $140.00.
http://cgi.ebay.com/ws/eBayISAPI.d [...] 5725668229
I'm very happy with the deal.
Thanks again everyone for all the good information,
Dennis
18dBi
> $150
> Close enough.
Reply to Anonymous
Interesting. The moonblink web site offers it for $169.
ebay sales that conflict with the sellers own web site fascinate me.
This looks like a continuing sale. There's another one open on ebay now.
As Jeff added up the prices, I would agree, for your RV application.
Neat, tidy, professional appearance. I would still prefer the $10
solution, but then I'm not neat and tidy.
This panel would be better on the front of the RV, rather than on the roof.
It isn't one of the flat/round TV antennas popular for RV use. It is a
panel antenna that wants to be vertical. Having it mounted on the front of
the RV would allow you to point toward the source, like parking at
McDonald's, facing the restaurant.
It is noted as a "weatherproof" assembly. I wonder if it would be happy on
the front of an RV driving into a rainstorm. It might need to be inside
the front window.
The documentation refers to Orinoco a few times, and the client looks like
the Orinoco Client Manager. Good card, inside a USB box.
Reply to Anonymous
Hi Clarence,
I'm going to mount it on the TV antenna boom. When I raise the antenna the
panel will be vertical and I can rotate it.
Dennis
roof.
of
on
> the front window.
Reply to Anonymous
I was thinking about shopping for free wireless connections while you were
driving down the road. Maybe it would work well enough while collapsed for
that purpose. Netstumbler and a GPS can plot the locations of wireless
hotspots onto a mapping program like Microsft Streets and Trips or Delorme
Street Atlas.
If it's mounted on an antenna mast, watch out for it being too close to the
roof of the RV. That's quite a large reflector. Jeff could probably speak
to required clearances. I think he made a comment earlier about shooting
across the tops of mobile homes.
Reply to Anonymous
I'll remember that and mount it as high as possible. I use to mount my
bag-phone directional antenna on the TV mast.
My trusty 3 watt bag phone has almost never let me down in the last six
years of traveling, but analog is going away and no one will program it
anymore. But it was very slow anyway (but dependable).
I definitely will be looking for free hot spots. I found one site that lists
many locations. Any other hints on how to find them?
Dennis
the
for
> Street Atlas.
the
speak
Reply to Anonymous
Because they are free, the lists aren't maintained in as fastidious a
fashion as a commercial list, but there are a few.
A Google search for 802.11 free hotspot returns 207,000.
Here are some I use.
http://www.boingo.com/search.html
http://www.ezgoal.com/hotspots/
http://www.bbwexchange.com/mblast/ [...] ID=CAWISPS
(change CAWISPS to something else for non-California search)
http://www.stayonline.net/hotels.php
Reply to Anonymous
I just got the Hawking USB and the performance is impressive. I have
used it outdoors in the rain simply putting it in a ziplock freezer
bag- no problems.
I tried this route because I like the idea of the antenna and the
receiver being as close as possible and therefore having no loss of db
on the cable or the cable connections.
The Hawking gave me very close to double the strength of 3 other
wireless USB adapters tested.
Mike
Reply to Anonymous
And you can use USB extension cables to extend the distance with NO loss of
signal, since it is digital on the USB cable.
Bob Alston
"M. Im" <schoeps@earthlink.net> wrote in message
news:e2a7a064.0410211415.7fcd644@posting.google.com...
> bag- no problems.
> Mike
>> > >Wireless-G
Version: 6.0.779 / Virus Database: 526 - Release Date: 10/19/2004
Reply to Anonymous
Tom's Hardware > Forum > Wireless Networking > General Discussion > Beginner needs help
There are 1462 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Help with wifi?
By Ubrales, 8 days ago:
Yes it will work fine! Earlier this week I installed two Linksys AE1000 wireless...
Best offers
