A while ago I had an old Asus GeForce2 card in my newly built sytem (athlon64 + msi k8n neo). The card made the system run VERY unstable and just before I pulled the card to get rid of it, I heard a loud "POP" come from near my machine. I smelled and visually checked for any physical damage, but didn't find anything wrong. I pulled the card and replaced it with a new GeForce6800. The machine ran great... for a while.
It slowly started behaving strangely with random read/write errors (corrupt files) and occasional BSOD's.
I replaced the PSU (now an Antec 450). The problems persisted, and slowly got worse.
Finaly my machine would barely even run windows, so i downloaded memtest86 and ran a test. Both my chips (tested individually) reported 1000's of errors. An identical chip from a friend reported 400 errors, and a higher quality Corsair XMS chip reported 0 errors. I sent the RAM off to be replaced and am currently running a fresh install of windows on that XMS chip.
So far so good.
However, I have received 2 BSOD's just recently with the error "PFN_LIST" I did check on this error and it reports either faulty drivers (all drivers are updated) or bad RAM as the source of the problem.
I re-ran memtest and it still reported 0 errors.
I'm deathly afraid that my mobo is going to kill my friend's RAM chip. Is this possible?
Could it be the onboard memory controller of the CPU?
What else could cause this?
Thanks!
So far so good.
Thanks!
