Well, I'm somewhat at a loss for how to troubleshoot this, as I can't even get a signal to my monitor to get any feedback in BIOS as to what is going on.
Here is my system:
Abit NF7-M
Athlon XP 2700+
Corsair Value Select PC2100 (2x256MB)
Antec PSU (came with the case; 350W)
When I turn on the system power, both LEDs on the motherboard come on, indicating that the motherboard has power and that system power is on, according to the manual. All fans and case LEDs work correctly.
Sadly, that's about all that's working right, as far as I can tell. There is no signal being sent to my monitor from the onboard video of the motherboard. I also tried putting in an old GeForce4 MX AGP card, which I know works (it's providing the video for the monitor I'm looking at now), and that didn't work either.
Any ideas as to what might be going on? I had a bit of a hard time getting the HSF on the CPU, so I am a little concerned that I might have damaged the CPU in the process. I will look into that tomorrow or Friday when I'm not so tired.
If the CPU isn't the problem (crossing my fingers), any other suggestions as to what the problem might be? I've built a couple systems before, but I've been fortunate enough in the past not to run into any tough troubleshooting issues like this.
Any help would be greatly appreciated.
ASUS K8V Deluxe SE | Athlon64 3200+ | Radeon 9800 Pro 128MB | 2X WD Raptor 74GB (RAID0) | 2X OCZ 512MB (PC3200, 2336) | SB Audigy2 Platinum
Here is my system:
Abit NF7-M
Athlon XP 2700+
