Tom's Hardware > Forum > Systems > HP > Virtual memory problem..........
Forum Systems : HP - Virtual memory problem..........
Archived from groups: comp.sys.hp.hardware (More info?)
Hi All,
I try to install Window XP professional in my computer but one problem
has " Virtual memory low... " something like that so any one can you
help me what can I remove from my virtual memory ?
Thanks.
Sponsored Links
The trick is to increase the amount of available virtual memory. Since you are
installing Windows XP, rather than tweaking it, the only way to increase virtual
memory is to add more of the real memory, SDRAM, DDR or whatever.
.... Ben Myers
On 6 Jan 2005 13:04:25 -0800, "bdisk" <bhav617@indiatimes.com> wrote:
>Hi All,
>Thanks.
Reply to Anonymous
bdisk wrote:
> Hi All,
> Thanks.
With XP, you really want at least 512 Megs of RAM installed for good operation,
regardless of what the instructions say. I'm guessing you've got a whole
lot less than that??
Reply to Anonymous
On 6 Jan 2005 13:04:25 -0800, bdisk <bhav617@indiatimes.com> wrote:
> Hi All,
Virtual memory is memory that is swapped out to the hard disk. Adding RAM
can help. But if you are that low on hard drive space, you either need to
delete old files, or need another or bigger hard drive.
Reply to Anonymous
There are 591 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
