Well, obviously I have a Abit IC7 Max 3, and for some reason the northbridge fan makes a wierd verrrrrrr noise whenever I boot up my comp, and continues to verrrr as long as the comp is on. But it only does it if I leave my comp off for overnight or longer, if its off for an hour or so it doesn't make the noise. The only way so far that was getting rid of the noise was to turn off my comp and then on until it didn't make the noise. I didn't know if this was common, or even a problem at all, or just a really annoying noise that doesn't hurt anything. My friend told me to grease it, and I wasnt too sure about that...ha. And other people tell me to replace it, but I don't even know where to get a fan to replace it with.
Just because im a hardware newb, doesn't mean I cant break things with a hammer.
