Help! AMD64 and ATI 9700 problems!
Last response: in Applications
December 6, 2004 5:06:30 AM
Hi all, i recently upgraded my PC to an XP3200+ 64 and the overall installation/setup went smooth BUT i cant get my 9700 running properly at all. Its defaulted as an un-known device and is using standard vga drivers (so at least i can get into my computer!)
But when i install the drivers (i have tried 4.11, 4.8 and 4.7) the same thing keeps happening - the install goes smooth the comp wants to reboot, upon re-boot, just after the xp splash screen it takes me to the windows is shutting down screen and just sits there and there are graphical glitches - if i leave that for long enough it goes to a DOS screen saying that the driver was in an infinite loop or something. If i reboot again i have to choose 'use last known setting that worked' to get back into windows, but then i am back at square 1! I dont know what i am doing wrong?
Any help would be great! Thanks guys!
December 8, 2004 2:37:59 AM
Have you installed the latest drivers for your motherboards chipset? It sorta sounds like the agp driver is old, bad, or not there.
<A HREF="http://www.folken.net/myrig.htm" target="_new">My precious...</A>
