Ok, have all parts nailed down - well, almost - and I know I want to go with an AMD 64 proc. 3200+ around there.
Now, here's my dilema -- if I want to pursue PCI-E ... I see that limited on the AMD side on MOBOs. There seems to be quite a number on the INTEL side but not very many out yet on the AMD side.
Also, seems to be a fairly hard choice between chipsets ... the 754 or the 939.
Looks like I need to just go AGP on video -- forget PCI-E on this system build ... AGP will probably be just fine for this system.
On the mobo - do I go for possible future growth with a 939 or just stick with a 754?
939 has dual channel ram - so that is a plus + possible future development for 939. Cons is it is newer...
754 is out longer, more out there right now and seems to be good.
what's ya'lls thoughts?
