Archived from groups: alt.internet.wireless,comp.dcom.modems.cable (More info?)
I just got a Motorola SBG900 Cable Modem Gateway. I don't have cable
internet yet but I connected the modem to my pc via Ethernet and I cannot
get to the configuration page. I just get the IE "Page Cannot Be Displayed"
error. Motorola Tech Support stated that I should be able to configure the
gateway even if there is no cable connected. Can anyone share any info on
this...perhaps tech support is wrong and I first need to connect it to
cable? I would rather not return it if there is nothing wrong with it.
What is your modem's IP address? What is your PC's IP address and
network mask?
I would also check if I have the right cable type, ie. straight vs crossed.
The modem gateway IP is something like 192.108.100.1 . I tried it with my
IP set to 0.0.0.0 and also 10.1.1.1 and a mask of 255.0.0.0. I checked the
cable type. It is ok.
Thanks.
"David Chong" <davidchong@iinet.net.au> wrote in message
news:417b444e$0$13760$5a62ac22@per-qv1-newsreader-01.iinet.net.au...
>> Displayed" error. Motorola Tech Support stated that I should be able to
>> configure the gateway even if there is no cable connected. Can anyone
>> share any info on this...perhaps tech support is wrong and I first need
>> to connect it to cable? I would rather not return it if there is nothing
>> wrong with it.
> What is your modem's IP address? What is your PC's IP address and network
> mask?
> crossed.
> David
When I hardcode the cable modem as the gateway and give myself an IP, it
works. When I set it to dhcp, I cannot get an address from the sbg900 dhcp
server. I get "the rpc server is unavailable" if i do an ipconfig /renew.
Thanks.
>> wrong with it.
> mask?
> crossed.
> David
I found the problem. I had the DHCP service set to manual. Once I set it
to automatic, it now works fine. Thanks.
"Saucer Man" <saucerman@nospam.com> wrote in message
news:wqOed.23219$Qv5.2847@newssvr33.news.prodigy.com...
> dhcp server. I get "the rpc server is unavailable" if i do an ipconfig
> /renew.
> Thanks.
>>> cannot get to the configuration page. I just get the IE "Page Cannot Be
>> mask?
>> crossed.
>> David
