HELP! I want to build a new system but I want to make sure I'm selecting good components, components that will all play together nicely. I built a system several years ago and it works (most of the time) but I've been plagued with lockups/freezes/crashes. My hope is some of you will have opinions on the brands I've choosen, chipsets, etc. Here's what I want to build:
CPU: Pentium 4 3.2Ghz 1MB Prescott 800Mhz FSB Socket 478
MOBO: ASUS P4P800SE Intel 865PE + 1CH5R Chipset, Socket 478, 800Mhz FSB, Dual Channel DDR400 AGP 8X SATA RAID
RAM: 1GB TOTAL, (512MBx2) Corsair VS512MB400C3 PC3200 CAS3 DDR400 Value Select
HDD: Western Digital WD2000JD, 7200 RPM, serial ATA 8MB 200GB
DVD Burner: Lite-On 1633S
SOUND: Creative Labs Soundblaster Live SB Audigy 2/ZS/Platinum Pro PCI MP3 Support
VIDEO: I want to re-use my recently purchased MSI GeForce4Ti4200 AGP card w/TV in/out 128MB
I would also re-use a CD-ROM (Samsung SC-125?) and probably by a new basic network card for my cable modem and home network. I'd like to keep my existing case and power supply (450W ATX)
Here's what I need the computer to do:
Using Firewire, take video from a to be purchased later digital video camera.
Play the latest cool games without locking up or crashing all the time
Backup my DVD movies, games, etc
Edit video from my cameras to make movies of my kids, and then burn them on DVD to mail out to relatives
Basic office functions, play music, kid games, etc.
Here are some of my questions:
1) Is the value select Corsair RAM okay? I also looked at Crucial memory, I want a good name brand memory. What about 533Mhz speed ram, can I not use that in the ASUS MOBO I selected? (or at least it won't be any faster?)
2) Any problems with the CPU/MOBO/Sound card configuration? I've always read a lot about certain sound cards in certain MOBO's causing random unknown problems that they don't find out about for a while.
3) Any problems using the current video card? I just bought it a few months ago, and have been happy with it. I realize PCI Express is the thing now, but I don't care about having the absolute latest thing, and this will give me a reason to beg my wife for a new computer in a couple years!!
4) Do I need to buy ram with heat spreaders with this system?
5) What about my current power supply? 450W should be fine right? I don't remember the brand.
6) Will the case I have now (with an Epox 8KTA3 MOBO & Athlon T-Bird 1.333 Ghz processor work with this ASUS MOBO or will I need a new case too.
7) Any recommendations on Heat Sink fans for this processor? The HSF needs to be made for this Socket 478 or the P4 3.2 doesn't it?
8) When I looked at DELL there web site mentioned that the SB Audigy 2 came with firewire support? Is it on the card or just something they do?
Thank you for your help and your opinions. Please let me know if you disagree with a choice I've made or if you have any info/experiences with these components.
Thanks so much
Mike
Thanks so much
Mike
