I'm in mainly for games and some MP3 does the Nvidia MCP-T variant sounds better than the plain MCP?
The Nvidia GPU (SoundStorm) is vastly superior to any other on-board solution available, but most motherboard manufacturers have cut costs by using a cheap DAC (Digtal -> Analogue Converter) chip. The upshot of this is that the <i>sound quality</i> is pretty much the same, unless you use digital speakers, and connect them to the motherboard's digital output (as this then isn't going through the DAC)
The other thing though is the capability of the Audio processor to take load off the processor. The MCP-T (soundstorm) variants will run games a few % faster (5-10% ish..) than either a MCP (non -T) nforce2 or another Chipset's solution - they're all software Audio, meaning the CPU has to compute all the sound effects as well as everything else, whereas MCP-T is a hardware solution, so reduces the CPU load.
One noteable exception to that rule is DoomIII. For some reason ID wrote the sound engine to not take advantage of hardware audio, so it runs entirely on the CPU, regardless of audio hardware.
For the record, I have a nforce2 MCP-T motherboard (Epox 8RDA+) and I think the sound's great.
The other thing, of course, is that if your AMP/Speaker setup is cheap, then it doesn't matter how good your sound hardware is, it'll sound the same...
"Sex without love is an empty experience...
But as empty experiences go, it's one of the best" - Woody Allen
