Ok mabe I exagerate some
Ok justa breif intro. last night I stuck a new NV silencer on my 6800 Ultra and a Zalman northbride cooler (the blocko meal no fan kind ) . before I did this everything was running fine had XP full installed on my WD Raptor 74GB no problem, only sligh glitch wasevry so often BIOS wouldnt detect it but it usually picked it up after a reset.
Anyway bascilly my system was running fine, previously had some memory instability which was cleared up with some extra 0.1v on the memory.
Now I put my card back in and loadup
Now I'm greeted by BIOS checksum error , default to orginal settings. ok I reset andthe prob goes away and I setup BIOS again
Now my 74GB is only detected every 3rd-4th time I boot up in a really hit and miss afair.
when itis detected and start to load windows it freezes. if it dosent freeze after bios it will freeze half way into loadup or just beforewindows should come up and gives me a range of error (non repeting) rangin from read write erros to dll files in BSOD.
Ok so I loadup safe mode. I manage to get into safe mode windows and ackup all myfiles onanother drive (thank crap for that) then reset
Now I cant even loadup safe mode anymore it freezes loading up the basic windows files.
Now before I go Nuke my C drive I was wanting your advice on possible things that could be wrong.
a few in my mind include corrupt windows mabe caused by mechanincal (aka me in the case hit somthn) or perhaps during one of the resets.
I've some how screwed up my board by shorting knocking or otherwise damgaing it so that its struggling wih my SATA drive
The HDD Raptor is on the fritz
(oh almost forgot I rana chkdsk under WInXP CD repair and it says its an unrecoginsiable partition !)
I'd ate to waste time trying to reinstall if its the drive thats bad
Orhave I possibl sorted out something on my board mabe I bent a SATA connector on the board (it isjust above the VGA card slot)
Anyway here's my system
Gigabyte K8NS Ultra 939
AMD3000
1024GB COrsair 4000 Pro Twinx
74GB WD Raptor
MAxtor 80GB
and an Antec 420W power supply cool blue
Any help would be great
AMD3000
74GB WD Raptor
MAxtor 80GB
