Closed
Help with crysis 1 (problem)
Last response: in Video Games
hi guys as you see the thread is about crysis :fou:  heres the problem
when i run crysis (all high setting not very high) no aa or anything res 1366x768
i get 26 FPS!!!!!(WTF) :o
my specs :
cpu: amd athlon ii x4 630 (2800)
gpu: ati radeon hd 5770 MSI
ram : 4gp
system : win 7 64
video driver catalyst 10.7
and on low setting with the same res i get max 34 fps so it must be a software problem non hardware problem and im usin version 1.2
what makes me belive its the game not my system is that i run resident evil 5 all maxed anti aliasing x 8 same res with min fps 58 and max 60 with vertical sync and the same setting with cod modern warfare 2 and im gettin 58-60 fps x8 with vertical sync so im not sure what to do guys
More about : crysis problem
well i know its a demanding game but every thing has a limit u know when i put every thing to low the game look like counter strike so it shouldnt get me a low fps
ive changed my res to 800x600 and i got max fps 46 is this believble or what
do you guys think its cuz im usin the exe in bin32 not bin 64 HhmmmmmM
Related ressources
my specs :
ram : 4gp
system : win 7 64
thats actually about what you should be getting.
Phenom II x4 3.84ghz
3gb DDR2 Ram
5770 OC'ed
i get around 30-32fps so its about normal. if anything i might consider rolling back to driver 10.4. thats what im using but i honestly doubt you'll see a difference.
Ask the community
