Firewire problem
Forum Motherboards & Memory : General Motherboard - Firewire problem
Wasn't sure where to post this, figured mobos would be the closet match.
My firewire is suddenly acting a little strange. For some reason, it will no longer detect my DV camera when hooked up. The same ports detect my external firewire hard drives, so its not a port problem, and I've tried multiple ports and even daisy chaining through my externall HDDs. I tried a different cable, so its not a cable problem. It worked last time I tried the camera... so I don't know what happen there. I have tried restarting the comp.
Any ideas as to what is wrong? I don't think the firewire hardware on the camera end went bad to you suppose? I haven't had a chance to test this on another computer. Any thoughts? Is there somewhere I can update my firewire drivers at, or...?
Thanks,
Dan
P4c 3.2Ghz @ 800MHz Northwood / ABIT AI7 / 1GB Corsair XMS-Pro CL2 Pc3200 / 160GB Seagate SATA 7200rpm 8mb cache / BFG-Tech Nvidia GeForce 6800GT 256mb / Antec Sonata case w/Antec TruePower 380W PSU
Sponsored Links
Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Firewire problem
There are 555 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
