Closed Solved
Star-Craft II: Wings of Liberty Display Problem
When i run the game (starcraft2) my monitor black out displaying signal frequency out of range. but i can hear the sound, i guess problem is due to its default refresh rate or resolution. i have reinstall the game n update my drivers but nothing seem to work, is there any way i can change the resolution without running the game? my current windows resolution is 1280X1024 with 75Hz. N its Model is Mitsubishi Diamond Plus 93SB.
13 answers Last reply Best Answer
More about star craft wings liberty display problem
  1. In your documents folder, there should be a folder called Starcraft II. Inside is a file named variables.txt. You should be able to edit the resolution manually from there.
  2. creepnormalmap=1
    creepQuality=3
    creepreflection=1
    creepselfshadow=1
    creeptrans=1
    foliagedensity=0.750000
    foliagequality=3
    GraphicsOptionEffectsDetail=3
    GraphicsOptionLightingQuality=3
    GraphicsOptionModelQuality=2
    GraphicsOptionMovies=3
    GraphicsOptionOverallQualityVer7[5]=3
    GraphicsOptionPhysicsQuality=3
    GraphicsOptionPortraits=2
    GraphicsOptionPostProcessing=3
    GraphicsOptionReflections=2
    GraphicsOptionShaderDetail=3
    GraphicsOptionShadowQuality=3
    GraphicsOptionTerrainQuality=3
    GraphicsOptionTextureQuality[2]=2
    lastDeviceId=1556
    localeidassets=enGB
    localeiddata=enGB
    localShadows=1
    MoviesSeen=1
    MusicHeard=1
    parallaxshadow=1
    particlelod=3
    particleobjects=1.000000
    particleterrain=1.000000
    physicsdensity=16
    ribbonlod=3
    sampleFOW=1
    shadowmapsize=2048
    softshadowTaps=12
    SoundAutoDetectCPUCoreCount=2
    soundchannels=32
    SoundQuality=1
    splatlod=3
    targettexeldensity=1.400000
    TerrainTextureLowResCacheSize=50
    TerrainTextureSize=768
    texQualityLevel=2
    texSpace[2]=500
    transparentshadows=1
    treadlod=3
    voicechatsoftwaremute=1
    watercaustics=1
    waterreflection=1
    waterrendertargetformat=3
    waterrendertargetsize=1024
    this is what my variable.txt file have, i dnt knw which one is 4 resolution?
  3. I'm sure mine had entries for the screen res as well, will go have a look, then you can add them manually.
  4. can u paste ur variable.txt so i can use it?
    I can't access my home PC at the moment. I will look for the entries that control resolution and tell you what they are.
  6. ok. i'll wait 4 ur reply.
  7. Best answer
    Found it!
    Add the entries:
    height=xxxx
    width=yyyy
    where xxxx and yyyy are the values you want.
  8. thnx dude i've finaly got it.
  9. Best answer selected by salmanstm.
  10. Pleasure! So did it work then?
  11. yeah it did work n still workin, i dnt knw y its missing in my txt file?
    I'm guessing it only adds the entries to the list once you make changes to the default resolution.
  13. This topic has been closed by Mousemonkey
PC gaming Games Resolution Video Games
