Archived from groups: alt.internet.wireless (More info?)
Hi,
I'm wondering whether I should add an antenna to my router, or replace
a remote 802.11g device with a more robust device, or both.
I have a d-link di-524 802.11g wireless router and a d-link dwl-g120
usb 802.11g dongle at a remote pc about 30 feet away. The remote pc
is a Dell Dimension 4600C, which contains only a single half-height
PCI slot, and I chose a USB dongle since there are few half-height PCI
802.11g cards on the market.
The remote PC functions as an HTPC (home theater PC), and therefore
sits on a low shelf in my TV cart. The positioning is very
unfavorable in terms of interference from all the nearby electronics,
and I rarely obtain good signals even though the router is only 30
feet away, and I frequently lose the signal entirely. OTOH, when I
bring a laptop home from work and wander around the house, I get good
signals on the laptop, so I think that the problem is due more to the
dwl-g120 dongle and its environment than to the router.
It would be relatively cheap and easy to add an antenna to the router,
but I don't know whether that will provide adequate two-way
communication if the dwl-g120 is unable to transmit adequately.
jaepstein_63@yahoo.com (Jonathan Epstein) wrote in
news:27e4d2e8.0410270516.7bb959b@posting.google.com:
> Hi,
> replace a remote 802.11g device with a more robust device, or
> both.
> dwl-g120 usb 802.11g dongle at a remote pc about 30 feet away.
> The remote pc is a Dell Dimension 4600C, which contains only a
> single half-height PCI slot, and I chose a USB dongle since
> there are few half-height PCI 802.11g cards on the market.
> therefore sits on a low shelf in my TV cart. The positioning is
> very unfavorable in terms of interference from all the nearby
> electronics, and I rarely obtain good signals even though the
> router is only 30 feet away, and I frequently lose the signal
> entirely. OTOH, when I bring a laptop home from work and wander
> around the house, I get good signals on the laptop, so I think
> that the problem is due more to the dwl-g120 dongle and its
> router, but I don't know whether that will provide adequate
> two-way communication if the dwl-g120 is unable to transmit
> adequately.
> Another alternative is to replace the dwl-g120 with a Hawking
> HWU54D high-gain USB wireless-G adapter:
> http://reviews.cnet.com/Hawking_HW [...] wireless_G > _adapter/4505-3380_7-30825857-2.html?tag=glance
> Do you have any opinions as to which will work better? Or
> should I just buy the router antenna and then try the USB device
> if necessary?
> Thanks,
> Jonathan
Try using a USB extension lead to position the USB dongle higher up
and away from metalwork as much as possible.
Reflectors for both would be pretty simple.
Is the dongle plugged directly into the computer, or is it on a cable?
If it's on a cable, you could simple put it about 1" in front of a flat
piece of tin, like a pie plate, oriented as a reflector toward the access
point. The orientation of my DWL-122 is important. It is not an
omnidirectional antenna. Are you using some signal strength indication to
orient the dongle?
You can put a simple reflector on the existing antenna of the access point.
Try an EZ-10 from http://www.freeantennas.com
You might be able to make a corner reflector for the dongle, but a flat
piece works for about 5 points on the NetStumbler scale.
Clarence A Dold - Hidden Valley (Lake County) CA USA 38.8-122.5
