This is going to be my first build. I need a budget system for general purpose use. It won't be used for gaming extensively (may be occasionally). I do intend to upgrade this to dual-core CPU whenever they become mainstream and affordable.
Here are the the important components. Please let me know if there are any compatibility issues you are aware of before I buy them.
- OCZ ModStream 450W PSU
- ASUS A8N-E nForce4 Audio/GB-LAN/IEEE/USB/ (don't need SLI)
- AMD Athlon 64 3000+ 512K 90nm (Venice)
- ATI (Sapphire) Radeon X700 Pro 128MBDDR3/PCI-E/TV-Out/DVI(Retail Box)(I think this will be good enough for me)
- Patriot Signature Series 1GB (2 x 512MB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Kit System Memory
Thanks in advance.
Thanks in advance.
