Yes No
Ads
Tom's Hardware > Forum > Computer Brands > HP > 7310 network installation problem on win2k
Forum Computer Brands : HP 7310 network installation problem on win2k
Archived from groups: comp.sys.hp.hardware (More info?)
I have just bought an HP 7310 all-in-ine printer.
I am using it on a small SoHo network using its built in network
connection.
It has installed successfully on one win2k machine on the network but
I'm having problems getting it installed on another. I can't get past
the "Connection Type" installation window where you select the network
connection rather than USB.
All that happens is that I click the "Network" check and then "Next"
and it thinks for a few seconds and returns to the "Connection Type"
screen. It doesn't bring up the window where it says it's searching
for the printer on the network at all.
I've been looking for differences between the system where it works
and the one where it doesn't but can't see anything significant really.
They're both at Win2k SP4 and I've checked through all the network
settings and they're basically the same. The machines are different
though, different motherboards, network card, applications installed
etc.
The software installs and works OK if I connect the 7310 to the USB
port so it *can* work on the machine. I contacted HP support and they
got as far as getting me to install using USB and then switch the
printer port to TCP/IP but while that gets the printer working a bit
(I can actually print on it) it's only one way and I can't see the
printer status and the FAX doesn't work.
Has anyone got any ideas what the problem may be and/or any ideas for
other things I can try to get it to install correctly?
Chris Green
Reply to Anonymous
I'm having the same issue as you are but with an OfficeJet 7410, any
luck so far
Reply to Charles
> luck so far
Yes, I have it installed OK now. I *think* the magic thing that I did
to get it installed was one of the two following:-
Disconnect all network drives
Remove all USB devices
It might also have been unnstalling some very old FAX software but
that seems unlikely to me.
The only remaining issues I have now are:-
Fax software goes very slow after you access the fax log, it's
quite OK if you don't acces the fax log.
I can't access Photo cards from the computer.
Chris Green
Reply to Anonymous
There are 2153 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What's a Good computer for $500 (to run on 32" tv?)
By C12Friedman, 8 days ago:
A sound decision (IMO)... now I'm going to refer you to the Systems - New Build area of...
Best offers
