Well, here's the deal. New build with a WD 74g Raptor SATA on a gigabyte K8NXP-SLI. IT seems that the MB does not see the HD. I boot to the Windows XP install disk & it sees the drive and fiormats it, etc and installs the first set of files. Then it re-boots but will not boot to the HD, only the CD.
Lets see... what else can I tell you? I go into BIOS and see no mention of the HD. It sees everything else on boot ( cd & DVD). Do I have to set up some sort of RAID setup? The manual is not very strong on this.
Thanks!
<font color=blue><b>just trying to put a little distance......
..... between causes and effects</font color=blue></b>
Thanks!
