Hi
I have upgraded my girlfriend's old Compaq Pressario 7464 (AMD K6-2 500Mhz) to an Albatron KM18GPro2 / Athlon XP1700+. Since my mATX case was really crappy I installed the Albatron board in her compaq case and then the wierd things happened:
1) USB connectors pins do not match the KM18GPro => I modified the case with a USB brancket I had.
2) The really wierd part: The connectors for powerLED/HDLED and powerswitch was to gether -> I used a knife to seperate them BUT the computer will not turn on if the print where the powerbutton are is touching the case (So I isolated it with tape , and powerLED/HDled is disconnected)
So Now I will installe the old Compaq motherboard in my mATX case , but I have tried to connect the powerswitch to the motherboard and nothing happens happen when I want to turn the computer on (the case and motherboard worked before I made the upgrade).
So what to do ?? do Compaqs have any special connection for powerswitch (due to my problem 2, I guess that could be the case?)
thx in advanced
thx in advanced
