I have updated my pc to sp2 but I'm not liking it. I have a DSL connection on my linksys router. But after installing SP2 internet is really really slow. InternetExplorer and Outlook don't work properly. But the strange thing is that if I connect my pc directly to the modem it does work fine. Or when I configure the proxy server, which is normaly only for dail-up access with my provider, it also works.
In normal set-up (behind the linksys router) I can internet without a problem using mozilla firefox, and I can sent e-mails with outlook express. But not with the programs I used before the update to SP2 and the settings I used before. (IE and Outlook)
I have tried multiple things already but nothing seems to work. My firewall and virusscan is turned off. I have already uninstalled SP2 and then everything works. But I would like to have the security updates.
Am I missing something obvious or is this just another example of Bill f*cking Gates programming skills?
What can I do about this?
