I just built a new computer:
epox 9npa+ motherboard
amd 3000 venice
evga 6600gt video card
wester digital hard drive
toshiba dvd burner
my father had a copy Windows XP Professional Version 2002 that he never opened, so I used that. The install went smooth. But the computer wont connect to the internet. It tried to create a connection when I opened Internet Explorer, seemed to set up correctly, but no connection. I have a cable modem. plugged the cable into my laptop and it worked fine, wont work on the epox.
Looked in device manager. I dont see anything even remotely resembling the gigabit lan thing. What would that be listed as? Only saw a 139four network adapter.
In control panel I see one network connection, a "139four Connection" (the four key on my keyboard does not work). Properties on it show that it is Enabled and connected for 35 minutes now (to what, I dont know). But the sent and recieved packets are 0. The ipaddress, subnet mask, etc are all<unavailable>
i dont know if windows sees my hardware correctly since it is a new motherboard, but XP from 2002. Worst thing to be broken is your internet connection. I cant upgrade any windows service packs.
Please help! Thanks in advance...
Could the motherboard be the problem?
Thanks,
Judy
amd 3000 venice
toshiba dvd burner
Thanks,
Judy
