Pavillion 753n and hard drive replacement
Last response: in Computer Brands
Archived from groups: comp.sys.hp.hardware (More info?)
I have a Pavillion 753n with an 80GB hard drive running win XP with
SP1 installed.. It is 90% full and i have purchased a new Western
Digital 250GB hard drive to replace it. The 80GB of course is
partitioned at 75GB NTSF in c drive and 5GB as d drive in Fat32 for HP
Recovery. I have heard some horror stories about copying one drive to
another. For instance i have read that the system will only see my new
250GB as a 137 GB. That it wont copy both c and d drive correctly,
that i will lose system restore and the list goes on. The new drive
came with software to assist in copying one to another, but it says
itself that on "brand name computers like HP and Dell" it sometimes
runs into problems. I have purchased Arcronis MigrateEasy and had
planned on using it instead. I've change hard drives in the past but
usually simply re-installed the os and everything else. I have far to
much this time to do so and copying in my best alternative. Anyone
with any experience at doing what i want to do? tia
More about : pavillion 753n hard drive replacement
"The new drive came with software to assist in copying one to another, but it
says itself that on "brand name computers like HP and Dell" it sometimes
runs into problems."
"brand name computers like HP and Dell" ??? Talk about FUD, fear, uncertainty,
and doubt. And stupid vague disclaimers. Dell and HP systems use pretty much
the same generic components as anybody else these days. Both change the generic
motherboard BIOS to impose their own look-and-feel, but the deep down inside
core of the BIOS which manages the hard disk does not change. These companies
sometimes (often in the case of HP) do pretty dumb stuff, but they have better
things to do than mess up a motherboard BIOS.
Suggestions:
Try Seagate's Seatools. I have used it many times with success to clone hard
drives, regardless of the manufacturer. If it works, you are home free. If
not, use the Acronis package. You may have to activate Windows again. Make
sure your computer is free of viruses and spyware before doing this.
.... Ben Myers
On Sat, 12 Feb 2005 08:22:01 -0500, krackerjak <krackerjak46@yahoo.com> wrote:
Suggestions:
.... Ben Myers
Gosh, the software didn't say anything specifically about BIOS's. If it
has trouble copying the idiotic hidden partition on his HP correctly, would
that come as any great shock??
David Kinsell wrote:
>> but it
>> uncertainty,
>> pretty much
>> the generic
>> inside
>> companies
>> have better
If it is doing a sector by sector copy, yes it would be a shock. Norton
Ghost can copy the disks fine, including the recovery partition.
craigm
>> but it
>> uncertainty,
>> pretty much
>> the generic
>> inside
>> companies
>> have better
craigm
Related ressources
- Grandma's Pavillion P-3_max hard drive size & type - Forum
- I can hear my computer doing things in my headphones.. like random digital noise - Forum
- HP Pavillion zv5000 compatible hard drives - Forum
- HP pavillion DVD & CD DRIVE - Forum
- no os cd to use after hd formatting - Forum
On Sat, 12 Feb 2005 14:46:03 GMT, ben_myers_spam_me_not @ charter.net
(Ben Myers) wrote:
you happen to mention one of my other fears in doing this..."you may
have to avtivate windows again"! How does that work?
>Suggestions:
>... Ben Myers
>Suggestions:
>... Ben Myers
If the hardware configuration changes substantially from the original on which
XPee was installed, the operating system will tell you that you have to activate
it. This is usually done somewhat painlessly via the internet. Sometimes,
Microsoft's product on-line activation balks at an attempt to activate, and you
are told to call an 800 phone number and talk to a Microsoft representative
usually speaking English as a second language. After you whine and plead to
explain why this happened, the Microsoftie will give you a long-winded code to
enter. Make sure you get all the letters and numbers correct and in the right
order. Should you succeed, your system will be reactivated. If XPee needs to
be reactivated, you get 30 days from the date of reinstallation to do so. If
you do not do so, your system probably will not boot.
If you have sensed from my description that product activation is a pain in the
ass, you are absolutely correct.
"If the hardware configuration changes substantially..." Ask Microsoft to
explain further.
"Sometimes, Microsoft's product on-line activation balks at an attempt to
activate..." Ask Microsoft to explain further... Ben Myers
On Sat, 12 Feb 2005 15:09:05 -0500, krackerjak <krackerjak46@yahoo.com> wrote:
>>Suggestions:
>>... Ben Myers
explain further.
>>Suggestions:
>>... Ben Myers
One thing with Windoze XP is that even with a very good program like Norton's Ghost,
you could end with real problem upgrading the harddrive. The scaring thing is not any
particular Brand of Computer. I have many cases that the newer HD will not even boot
like there is no boot sector on the HD yet I could put it in another system and it
will come up and asked to Registered again. Hope you do have a very good back up of
all the data you can't afford to loose on CD or tape drive first. It is a good thing
to do first.
Dewaine
> explain further.
> >>Suggestions:
> >>... Ben Myers
to do first.
Dewaine
> explain further.
> >>Suggestions:
> >>... Ben Myers
If you have not already done so, I would create the recovery tools CD and
recovery DVD or CD's just in case you run into a problem with the recovery
partition (which is actually the first partition and not hidden).
If your 753n is newer than my a530n, then it should support larger drives
(mine came with 200 GB drive). If for some reason your system does not
support the drive size, the software included with the drive usually
includes drive overlay software to make that work (along with disk copying
software that should be compatible).
>>> another, but it
>>> runs into problems." "brand name computers like HP and Dell" ???
>>> pretty much
>>> the generic
>>> inside
>>> companies
>>> have better
>> would
That would be a brilliant idea, wouldn't it? Copy a 40 gig drive sector
by sector to an 80 gig drive, and you end up with a drive that looks just
like a 40 gig drive. Wonder why no body does that????
>>> another, but it
>>> pretty much
>>> the generic
>>> inside
>>> companies
>>> have better
>> would
>>>> another, but it
>>>> sometimes
>>>> pretty much
>>>> the generic
>>>> down inside
>>>> companies
>>>> have better
>>> would
>> Norton Ghost can copy the disks fine, including the recovery partition.
If you knew anything about Ghost, you also know it can resize partitions.
You could also create a second partition.
>>>> another, but it
>>>> sometimes
>>>> pretty much
>>>> the generic
>>>> down inside
>>>> companies
>>>> have better
>>> would
Let me take a sec and thank you for your assistance.
Basically all went well using Arcronis MigrateEasy. It allowed me to
resize my partitions(almost). And it did have a read earror on sector
1, i retryed several times and then ended up ignoring. Everything at
present appears to be working fine. Two more quick questions. When
partitioning the new drive it did not allow me to create new
partitions. It attempted to simply resize them in poportion to the
new drive. I ended up with a C drive of about 217 GB, and left D at
the 5 GB it was on the 80 GB hard drive. The program stated that I
had about 232 GB to work with. Thus I ended up with 10 GB of
unallocated space. Can I recover that? Also now that all is
operational with the new drive, I installed the old 80 GB as a slave.
I never did erase the data on it. How do I go about erasing those 80
GB and if possible partitionng it? Once again tia.
>>>>> another, but it
>>>>> sometimes
>>>>> pretty much
>>>>> change the generic
>>>>> down inside
>>>>> These companies
>>>>> have better
>>>> If it
>>>> correctly, would
Yes, I'm quite familiar with Ghost, thank you. Of course when it resizes
partitions, it sure isn't doing a sector by sector copy, is it? Not that
the issue has anything at all to do with the freebie software that the OP
was asking about. Hidden partitions frequently trip up disk copying software,
as people who know anything about the subject realize.
>>>>> another, but it
>>>>> sometimes
>>>>> pretty much
>>>>> change the generic
>>>>> down inside
>>>>> These companies
>>>>> have better
>>>> If it
>>>> correctly, would
Related ressources:
- ForumHP Pavillion dv7 black screen.
- ForumWhat is largest hard drive upgrade for HP Pavillion laptop?
- ForumA8M2N-LA (HP Pavillion A1730N) wont boot, no beeps
- ForumWill a Pavillion XT856 support a mATX motherboard
- ForumRecovering data from hp pavillion hard drive without the laptop
- ForumHow to change the mother board in a HP Pavillion p6310f
- ForumCan I use my old HP pavillion case to build a new desk top?
- ForumSimple Upgrade to My Hp Pavillion a1250n
- ForumLaptops admin passwords
- ForumWhat Power Supply To Buy as a Replacement
- ForumRemove Hard Drive from Pavillion n5170
- ForumUpgrading hard disk in notebook
- ForumNo Sound with WinXP & hard drive partitions questions ?
- ForumHP Pavillion a345w takes an extremely long time to boot up
- ForumHard Drive Problem
- More resources
Read discussions in other Computer Brands categories
