I just got some new parts from newegg to rebuild my system and put them together and i cant seem to get them working. The system will post but when i try to install windows, it get part of the way through and then goes to a blue error screen. It does not do it at the same point in the installation - each time it is at a different point in the install.
so heres the hardware i got:
1) Mobo: MSI K7N2 Delta2-FSR Socket A (Socket 462) (http://www.newegg.com/Product/Product.asp?Item=N82E16813130512)
2) CPU: AMD Mobile Athlon XP-M 2500+ (45W) Barton 266MHz FSB Socket A (http://www.newegg.com/Product/Product.asp?Item=N82E16819103401)
3) RAM: mushkin Value 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System (mushkin Value 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System )
4) CPU Fan: Thermaltake Silent Boost 80mm Ball Cooling Fan/Heatsink (http://www.newegg.com/Product/Product.asp?Item=N82E16835106037).
we had to fiddle with the CPU settings in the bios to make it come up right because by default it came up as a 600MHz Processor. And the best settings we could get to work were 266 x 11 x 1.55v that puts the cpu at 2200mhz. however we did not touch the memory settings in the bios - perhaps we need to?
any advice would be appreciated.
