XP Start-up & Shutdown problems.
Last response: in Windows XP
Recently, I replaced the factory motherboard & processor that came with my emachines desktop(Model W1500) with a GigaByte 7KVM400 and an XP 2400+ proc. I didn't replace the case because I didn't have the money at the time, so I used the existing case.
Afterwards, I upgraded to xp-pro sp2 and since then I cannot shutdown at <b>all</b>. Windows hangs everytime after the 'saving your settings' dialog and I must hold the power button until the machine shuts off. Furthermore, whenever I have my usb mouse(mx510) plugged into it's port at boot time, the start up process lags for almost 4 minutes, and when windows comes to, the mouse does not work. I must unplug/replug for it to function. If anyone has had an experience similar to this, help would be appreciated.
A friend of mine had a similiar problem with Windows XP SP2. He upgraded from Win2k to XP and weird problems started. He ended up reinstalling XP from scratch.
Did you upgrade from a Fat32 partition maybe? What OS did you upgrade from?
I would recommend a new install of XP though.
Riser
I aways do a full backup before installing a service pack on a machine that has been in use for awhile. About half the time the new system acts weird.
When I first tried upgrading from SP1a to SP2 I had similiar problems.
Then I restored from a backup taken just after I did a clean install of XP and all my software, but before I actually used the system. System ran great.
Still I would feel better having done a clean install from an SP2 CD. :)
Ask the community
