Tom's Hardware > Forum > Systems > HP > Dual-side printing on Officejet 7310 running SUSE 9.1 & CUPS
Forum Systems : HP - Dual-side printing on Officejet 7310 running SUSE 9.1 & CUPS
Archived from groups: comp.sys.hp.hardware (More info?)
My home network consists of two identical Dell Dimension 4800 boxes, an HP
Officejet all-in-one 7310 printer, a D-Link router and a Motorola cable
modem. One Dell box runs only Windows XP home, while the second box is a
dual-boot Windows XP Home and SUSE 9.1 Linux. The printer works flawlessly
when running under Windows XP on both machines. Of the many HP printers I
have owned, the OJ 7310 is the first to satisfy my requirements. In my
opinion this one heck of a printer for home/small office use.
However, when running Linux, the printer will not print dual-sided. I am
using CUPS and have defined 2 print queues, 1 queue for single-sided
printing and a second for dual-sided printing.
The OJ 7310 replaced a OJ 6110, which had the dual-side modification and
functioned correctly for both single & dual-sided printing under CUPS.
From what I have found on the WEB it appears the PPD file I am using
supports double-sided printing under Linux/CUPS.
From the HP-OfficeJet_7300-hpijs.ppd file:
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ *% You may
save this file as 'HP-OfficeJet_7300-hpijs.ppd' *%
*FormatVersion: "4.3"
*FileVersion: "1.1"
*LanguageVersion: English
*LanguageEncoding: ISOLatin1
*PCFileName: "HPIJS.PPD"
*Manufacturer: "HP"
*Product: "(officejet 7300 series)"
*cupsVersion: 1.0
*cupsManualCopies: True
*cupsModelNumber: 2
*cupsFilter: "application/vnd.cups-postscript 0 foomatic-rip" *%pprRIP:
foomatic-rip other
*ModelName: "HP OfficeJet 7300"
*ShortNickName: "HP OfficeJet 7300 hpijs" *NickName: "HP OfficeJet
7300 Foomatic/hpijs (recommended)" *PSVersion: "(3010.000) 550"
*PSVersion: "(3010.000) 651"
*PSVersion: "(3010.000) 652"
*PSVersion: "(3010.000) 653"
*PSVersion: "(3010.000) 704"
*PSVersion: "(3010.000) 705"
*PSVersion: "(3010.000) 800"
*LanguageLevel: "3"
*ColorDevice: True
*DefaultColorSpace: RGB
*FileSystem: False
*Throughput: "1"
*LandscapeOrientation: Plus90
*TTRasterizer: Type42
*OpenUI *Duplex/Double-Sided Printing: PickOne *FoomaticRIPOption Duplex:
enum CmdLine A *OrderDependency: 120 AnySetup *Duplex *DefaultDuplex: None
*Duplex DuplexNoTumble/Long Edge (Standard): "%% FoomaticRIPOptionSetting:
Duplex=DuplexNoTumble" *FoomaticRIPOptionSetting Duplex=DuplexNoTumble: "
-dDuplex=true -dTum&& ble=false"
*End
*Duplex DuplexTumble/Short Edge (Flip): "%% FoomaticRIPOptionSetting:
Duplex=DuplexTumble" *FoomaticRIPOptionSetting Duplex=DuplexTumble: "
-dDuplex=true -dTumbl&& e=true"
*End
*Duplex None/Off: "%% FoomaticRIPOptionSetting: Duplex=None"
*FoomaticRIPOptionSetting Duplex=None: " -dDuplex=false" *CloseUI: *Duplex
I am not experienced in Linux and feel there is probably some simple thing
I am overlooking in either the CUPS or printer setup, however I haven't
the remotest idea about where I should start looking to find the problem.
I would really appreciate any suggestions offered which will allow me to
find and correct my problem.
Thanks
Sponsored Links
There are 1268 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
