Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Any device to connect home wired Ethernet to outside 802.1..
Forum Wireless Networking : Wireless General Discussions - Any device to connect home wired Ethernet to outside 802.1..
Archived from groups: alt.internet.wireless,comp.sys.laptops (More info?)
Is there any wireless device (802.11 type. compatible with WiFi
hot spots) that would interface to the outside WiFi network and
connect local devices with Ethernet cable, i.e. it would act as a
router, firewall for local wired dekstops/laptops and provide access
to Internet through a single 802.11 port. It would be a *reverse* of
the popular Linksys wireless router that connects to Internet through
a wired port.
Sponsored Links
> a wired port.
It's not clear what exactly you're looking for that a Linksys, Netgear,
Belkin, or other brand of WAP with switch doesn't provide.
--John
Reply to jclarke at ae tee tee global dot net
(was jclarke at eye bee em dot net)
Reply to Anonymous
Archived from groups: alt.internet.wireless (More info?)
On Sun, 07 Nov 2004 15:05:28 -0500, in alt.internet.wireless , "J. Clarke"
>> a wired port.
He wants to connect wirelessly to someone else's wireless network. A
wireless router provides wireless on the LAN side, not on the WAN side.
To the OP: you could (probably) do this with a wireless AP that can act as
a client, which you would then have to plug into the WAN port of an
ordinary router. I've never tried it.
Mark McIntyre
CLC FAQ <http://www.eskimo.com/~scs/C-faq/top.html>
CLC readme: <http://www.ungerhu.com/jxh/clc.welcome.txt>
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Reply to Anonymous
On Sun, 07 Nov 2004 15:05:28 -0500, "J. Clarke"
>> a wired port.
Are you saying that I can take a wireless router like Linksys WRT54G
that mentions only one interface to backbone Internet through its
wired Ethernet port and then use it in reverse, i.e. use its wireless
interface for backbone Internet and connect a laptop to the router
with an Ethernet cable. Manual does not mention such a setup.
Reply to Anonymous
>>> a wired port.
Connect the laptop to one of the switch ports. The WRT54G has four of them.
--John
Reply to Anonymous
On Sun, 07 Nov 2004 19:25:22 -0500, "J. Clarke"
It has also one port for power supply!??%^*^??
Frankly, leave the subject to folks who know more about wireless.
Reply to Anonymous
>>them.
I'm not sure I understand what point you think you are making about having a
port for the power supply. The device in question, if you will be kind
enough to go to the Netgear site and look at the datasheet, is a
multipurpose device combining a four port Fast Ethernet switch, an 802.11g
WAP, and a NAT router with some other bells and whistles providing a fifth
Ethernet port. He can connect his laptop to any of the four ports of the
Fast Ethernet switch and it will be able to access devices connected via
802.11g.
--John
Reply to Anonymous
"MMM42" <MMM42@nospam2.com> wrote in message
news:418e7aa9.261502718@news-server.cfl.rr.com...
> a wired port.
What you want is a wireless bridge. Linksys, DLink, and I would bet many
others make them. The ideal one would be one that is the same manufacturer
as the WAP of the originating network.
Reply to Anonymous
Im doing this with a dlink 604+ adsl wireless router and a dlink 900ap+
setup as an AP client. But if you do this, you *cant* use the AP in
client mode as an AP, so your wireless cards wont connect to it
(only the ethernet port would work).
You must setup it as a bridge, and it's *really* better if you use same
brand (dlink with dlink, linksys with linksys etc..).
I successfully used a linksys AP as a client of the dlink router, but
i couldnt use it as a bridge
Reply to Anonymous
There are 1217 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
