Hi
I have a bit of a problem with one of my PCs which I was hoping someone might be able to help me with. Originally it was an HP PAvillion 8230 Pentium II 233Mhz with built in ATI Graphics. I have just changed the mobo to a Gigabyte GA-5AX with an AMD K6-500 cpu and an Elsa Erazor III TNT2 Pro AGP card. Everything seems to work ok but now when I shut down windows it gets as far as the "you can now switch off your computer" screen, and then instead of shutting down it goes to a blue screen windows protection fault saying the system has been halted and you must reboot!??
I can't work out why it is doing this, any ideas?
Also is it me or is upgrading an HP a bit of a nightmare? I noticed the sound card is made of of two parts and powers the speakers. Now I've upgraded from Win 95 the speakers make a nasty noise when you switch the PC off!
Well I hope someone can help!!!
Thanks
Andy
Thanks
Andy
