G
Guest
Guest
Hey, all, I was wondering if anyone could answer a question for me. I've found an excellent deal on a K6-III+ 450 MHz processor, and I have a Gigabyte GA-5AX mobo. I saw in a pretty old post that the mobo is in fact compatible with the chip using the F3 BIOS.
Reading the specs for the chip, the voltage needs to be either 1.8V or 2.0V. The manual for the mobo only has settings for 2.2V - 3.0V, but the Gigabyte website says it can support 1.3V - 3.5V. (www.giga-byte.com/products/ga5ax4.htm)
Anyone know the settings for the switches to get the 1.8V or 2.0V required for the K6-III+? I really appreciate it if you do!
