Tom's Hardware > Forum > Systems > HP > HP Vectra VL 6/266 Battery ? Manual ?
Forum Systems : HP - HP Vectra VL 6/266 Battery ? Manual ?
Archived from groups: comp.sys.hp.hardware (More info?)
Hi!
I tried to find the battery on the main board, but couldn't find one.
According to the i"Upgrade and Maintenance Guide HP Vectra VL series 7",
which I downloaded with some difficulties ( I had
to remove the part of the URL after "pdf" ) from the hp-web-site, says:
"You can also install an external battery in the PC, which you can order
from your authorized reseller."
But actually it doesn't say what else I could do....
The external battery is:
3.6V battery pack - 950mAh, lithium, with cable and connector
and it costs $69.00
So I would like to know where is the internal battery and which pin, for the
external one, is (+) ?
There are 3 pins like II I
Best thing is probably using a time server when setting the time gets too
boring ;-) ( I'm running OpenBSD on it)
Thanks for any help!
Michael
Sponsored Links
There are 1131 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
