Tom's Hardware > Forum > Systems > HP > Serious performance problems
Archived from groups: comp.os.linux.redhat,comp.sys.hp.hardware (More info?)
Hello there,
I'm having a strange and serious performance problem with Redhat 7.3
running on a HP ML350 G3 dual Xeon server with 1.5 GB of RAM and three
RAID disks on a 641 controller.
Server seems to work all right for three, four, even six days. Then it
becomes absolutely unresponsive but it does not crash. It will not
even display a console screen.
I decided to run via cron the free command each 10 minutes, log this
information and create line graphics to analyze the problem. After
rebooting the server I can see:
1. It takes 2.5 hours for free memory to drop from 1.2 GB to 11 MB.
2. Cached memory grows to almost all free memory and then starts a 45
degree decrease which ends in around 75 MB then it becomes
unresponsive.
3. Between 12 and 24 hours before becoming unresponsive memory buffers
suffer a strong decrease and then a steady decrease, reaching values
of 1120K.
This server runs apache, tomcat, postgres, AWStats and tapeware backup
software.
Any help will be greatly appreciated, since I really do not know were
to start.
Could it be Postgres memory settings?
Kernel memory settings?
I have these graphics and memory value table in Excel, if anyone would
like to see them please let me know and I'll send it via email.
thank you all
Sponsored Links
Archived from groups: comp.sys.hp.hardware (More info?)
On the seventh day, Rodrigo Filgueira Prates wrote...
> [snip, memory disappears]
sounds like you're having a memory leak. My bet: check the web for memory
leak and each of the programs you're running as well as RedHat 7.3. Maybe
you find something. If not, upgrade the software packages one by one. It
may very well be that some of the applications in Tomcat (if you have
programmed them yourself) is causing troubles for you. If it is any
counsellation for you: at work I am facing the same troubles on Fedora Core
2 and some self developed Tomcat apps (not programmed by me, though) and
MySQL, causing NFS to fail.
I wish you luck - such memory leakages are always a pain in the neck to
diagnose.
BTW: You might check for the most recent BIOS as well.
xpost deleted and followup to comp.sys.hp.hardware
mit freundlichen Grüßen/with kind regards
Christian Dürrhauer, Institute of Geography, FU Berlin
100,000 lemmings can't be wrong.
Reply to Anonymous
There are 1211 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
