gorillateets Distinguished Sep 13, 2010 51 0 18,630 Jan 1, 2011 #1 I'm trying to figure out if Gamebryo 1.0 is the same as Gamebryo 2.0. Is the base code pretty much the same or was Gamebryo 2.0 worked from the ground up to make Oblivion? Thanks.
K ksachdev Distinguished Jan 1, 2011 13 0 18,520 Jan 1, 2011 #2 I don't know much about the engine, but I've played through both games thoroughly and they look and feel pretty much the same. Upvote 0 Downvote
gorillateets Distinguished Sep 13, 2010 51 0 18,630 Jan 1, 2011 #3 Thank for the reply. I was looking for something more specific but I'm not hopeful for a detailed answer. Upvote 0 Downvote
strangestranger Splendid Jan 31, 2006 4,675 0 22,860 Jan 1, 2011 #4 Not precisely the same but I believe different versions of the same engine. http://en.wikipedia.org/wiki/XnGine That, according to wikipedia was the engine it was supposed to use and includes links to the engine it does use. Upvote 0 Downvote
jaguarskx Titan Apr 19, 2006 27,979 3 84,965 Jan 2, 2011 #5 Morrowind used v1.0 while Oblivion used v2.0. Gamebryo v2.0 was not specifically designed for Oblivion. It is a cross platform engine which Bethesda licensed to be used for their games. Upvote 0 Downvote
