Yes No
Ads
Tom's Hardware > Forum > Computer Brands > HP > HP DeskJet 970Cse Problem
Forum Computer Brands : HP HP DeskJet 970Cse Problem
Archived from groups: comp.sys.hp.hardware (More info?)
If I send a document to the printer to print, it will print all colors
except black.
Here what I have tried: I have changed the ink cartridge twice. I ran the
printer through several cleaning cycles. I have tried the manual priming
thing. I have cleaned the contacts with distilled water and the cotton ear
swabs. I have updated the driver. I've also tried the hardware reset,
where you remove the USB cable and the ink catridges, and then removed the
power cable for two minutes.
A friend suggested that the PCB may have gone defective. And since the PCB
costs more than replacing the entire printer, that is not an option. I hate
it because I REALLY like this printer.
Any more ideas would be GREATLY appreciated!
MikeS
Reply to Anonymous
Hi there,
Have you checked your printer settings in the properties and toolbox??
I have a 970cxi which I think is very similar and in the print toolbox in
the configuration tab there's a configure print cartridges there, but mine
is greyed out. If yours isn't greyed out, it may be possible it's set not to
use the black cartridge.
Or there may be another place where this setting may be enabled.
Sometimes uninstalling a driver and reinstalling it won't reset the settings
as they may be held somewhere in a file or in the registry and that isn't
being deleted when you uninstall the driver and software.
Does this happen in all applications?
It could also be a shared printing preference in your applications, but I
couldn't see an option for my printer that would cause that.
If you can't find a setting that changes this, and if you have access to
another computer, it may be worth hooking it up and seeing if it still does
it or not, and if it does, then it's the printer, if not, it's the software
and or drivers.
Good luck
"Mike/CathyS" <tmsNOSPAM@go-concepts.com> wrote in message
news:8a767$42543f03$cf287b4d$28321@FUSE.NET...
> except black.
> ear
> PCB
> hate
> MikeS
Reply to steven
- 0 +
Hi Mike
What follows is the internal test for the 900 series printers.
HP Deskjet 916c, 920c, 930c, 940c, 950c, 970c, 960c, 980c, and 990c series
printers
Running a sample page
NOTE: This test does not work with the HP Deskjet 6840 series.
Turn the printer on.
Press and hold the RESUME button until the printer starts printing.
Release the RESUME button.
Running a self-test
Press and hold the POWER button.
Press the RESUME button four times.
Release the POWER button.
Running a diagnostic test
Press the X (Cancel Print) button eight times.
Two-sided printing module (duplexer) test
Press and hold down the POWER button.
Press the CANCEL (X) button three times.
Press the RESUME button once.
If the test works then you have a driver and or PC problem (maybe a cable
failure in rare cases), if the test does not work (ie black fails to print)
then you have a bad black cartridge or a failed logic board in the printer. If
the test works then I suggest you completely remove all traces of the 970
drivers and re-install them.
Go to
http://h10025.www1.hp.com/ewfrf/wc [...] e=bpd09143
to see HP's troubleshooting page for 900cse.
Good luck
Tony
>except black.
>MikeS
Reply to Tony
There are 2059 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What's a Good computer for $500 (to run on 32" tv?)
By C12Friedman, 8 days ago:
A sound decision (IMO)... now I'm going to refer you to the Systems - New Build area of...
Best offers
